full flow oil filtering - Ford Truck Enthusiasts Forums
Old 03-27-2006, 01:46 AM
ol'blue52 ol'blue52 is offline
ol'blue52 is starting off with a positive reputation.
Just wondering if anyone is using a full flow oil filtering system on their flathead V-8 engine?
Is it really worth the extra money on an occasional driver or would a stock filter with high quality oil and frequent changes be just as good?
Thanks,
Jesse
Old 03-28-2006, 05:07 PM
F6Guy F6Guy is offline
F6Guy is starting off with a positive reputation.
I too am looking at converting my motor to full flow filtering. Motorcity flathead has a pretty neat kit but its kinda pricey. But then again so is an engine rebuild. My main reason for doing this is so I can also install an oil cooler as well as a good spin on filter. I belive it to be worth the money to convert to a full flow system in the long run if the vehicle in question will be driven with any reularity, as far as every now and again I guess its not as critical.
Old 03-30-2006, 06:04 PM
flathead239's Avatar
flathead239 flathead239 is offline
flathead239 is gaining momentum as a positive member of FTE.flathead239 is gaining momentum as a positive member of FTE.
Flathead oiling
I have the Motorcity full flow kit in my flatty- excellent design & highly recommended.
As a bonus, it makes prelubing the motor prior to first startup each season a breeze!
Jeff
52 F3
Old 07-07-2008, 04:20 PM
ssj7kids's Avatar
ssj7kids ssj7kids is offline
ssj7kids is gaining momentum as a positive member of FTE.ssj7kids is gaining momentum as a positive member of FTE.
Ok, I know this is an old thread, but it came up when I did a search.
My engine guy is recomending a full flow filter and I want to use the existing filter to keep the stock look. His advice/reasoning is that the motor we are re-building had the oil ways in the crank completely plugged. His reasoning is that when you shut down the engine, any impurities in the oil will settle where they are, and stay there. With the old Flattie, only part of the oil goes through the filter and so your oil will always have stuff in it. I'm thinking especially with an occasional use vehicle this could be a bigger problem, rather than on a daily driver.
Has anyone had experience using the existing oil canister, and converting it to a full flow with a spin on filter?
Thanks in advance,
Steve
Old 07-07-2008, 07:27 PM
jmadsen's Avatar
jmadsen jmadsen is online now
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
I dont know about using the existing can, but I heard someone mention using the original filter can as a small on engine tool storage compartment that way you can leave it on there for the looks but mount the real filter somewhere else. Not sure what tools would actually fit in there though?
I am also thinking I want a full flow filter setup on my engine assuming I ever get it in for rebuilding.
Josh
Old 07-08-2008, 05:41 AM
55 f350's Avatar
55 f350 55 f350 is offline
55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold55 f350 is a splendid one to behold
it's on the wish list for me too . unfortuneately it's quite long ......................
Old 07-08-2008, 07:19 PM
petey shoes petey shoes is offline
petey shoes is gaining momentum as a positive member of FTE.
well, might as well add my two cents--use my flattie almost every day. have a partial flow spin on filter (FOR EASE AND NEATNESS OF OIL CHANGE) connected to factory location. change oil three times a year and always clean. i'm not saying that oil doesn't get dark, cause it does, but it's not gritty or "fugly"! i also have a 3/4" magnet on oil drain plug-just in case. i definetly agree that full flow is BEST,but you can get away with partial. just keep clean oil in engine to prevent sludge buildup!
Old 07-09-2008, 01:16 AM
effie_man's Avatar
effie_man effie_man is offline
effie_man is gaining momentum as a positive member of FTE.
its on my list for this winters rebuild but i kinda like the nostagic look of the stock cannister filter. I think the stock cannister is ok as long as you spend the time to clean the hell out of everything once and then maintain it with frequent oil changes etc. It should be fine.
Old 07-11-2008, 11:53 PM
Kruse Kruse is offline
Kruse is gaining momentum as a positive member of FTE.
Quote:
FWIW, (nothing) oil has come a long way over the last 60 years and I think modern oil, be it dino or synthetic, will not have the sludging or varnishing problems that older engines were subjected to. But.....do as you wish.
Old 08-30-2008, 11:06 PM
jmerson jmerson is offline
Old Timer
jmerson is starting off with a positive reputation.
Red's Headers has an install kit for not much money that is mainly a diagram on what to do to make the engine full flow. I did it on my 296" somewhat loaded engine and it works great. Not many miles but good oil pressure at all RPM's. Well worth the time and money because now every drop of oil is filtered.
Jim
Old 10-13-2008, 12:33 AM
Hades212 Hades212 is offline
Hades212 is starting off with a positive reputation.
I bought a full flow kit off of E-bay but im not sure what it cost now.
Old 10-13-2008, 12:24 PM
Old Timer
external pump
I don't know if this thread is still alive but has anyone ever done an external oil pump setup on a flathead? I got a three stage Moroso pump and going to put pickup tubes in the pan and was wondering if any one has any experience along these lines?
Jim
Old 10-15-2008, 09:45 PM
the only problem with reds kit is the motor needs to be dissasembled for install which sucks if the motor in question is up and running
1984 Ford Ranger Diesel Perkins 2.2L - Oil Filter Question RJthe84ranger General Diesel Discussion 1 08-23-2016 05:46 PM
oil line to use for remote oil filtration system speakerfritz 6.4L Power Stroke Diesel 0 12-11-2015 09:42 AM
Ford Racing oil filter adapter hillcountryflt Ford Inline Six, 200, 250, 4.9L / 300 11 09-20-2015 10:37 PM
Oil filter question Mixer man 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 04-20-2015 09:11 PM
True Flow Air Filter 92merc 1997 - 2003 F150 6 03-29-2005 04:32 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
diagram, filter, filtration, flathead, flow, ford, full, fullflow, kit, modify, oil, oiling, pump, sludge, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
