brake bleeder screw stripped, please help - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-26-2006, 10:31 PM
axp117crow axp117crow is offline
axp117crow is starting off with a positive reputation.
so i had a leak in my brake line yesterday and fixed it today, like pulling teeth. i've never had so many problems changing break lines or bleeding brakes. anyway i stripped both rear brake bleeder screws. i had to bleed the brakes by loosening the brake line itself. most of the air is gone but some still remains. anybody have any ideas on how to get the stripped screws out so i can bleed my truck correctly? i sprayed the crap out of them with pentrating oil and used vice grips and stuff like that, i'm just lookin for ideas if anyone has any.
Old 03-26-2006, 10:57 PM
natebaker's Avatar
natebaker natebaker is offline
natebaker is starting off with a positive reputation.
Yikes... How old is the truck? A pair of channel locks or the correct sized end-wrench should do the job just fine. It could've possibly been a metric sized screw (for lack of a better word) and you could've been using SAE wrenches; or even the other way around. The big deal now is getting them out without further damaging the screws. Relieving the pressure off the brakes by disconnecting the brake line may help to get the screw out. Other than that, just make sure you have a good grip on it if you're using vice-grips or channel locks.
Old 03-26-2006, 10:59 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile CowboyBilly9Mile is offline
CowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to all
As cheap as rear wheel cylinders are, I would just buy new ones. If you want to battle it, an easy out might be worth a try.
Old 03-27-2006, 05:03 AM
Dan Robertson Dan Robertson is online now
Dan Robertson is starting off with a positive reputation.
Try using a hammer. I'm not kidding. Tap on the bleeder screw a few times, like you were trying to drive it in like a nail. Sometimes that will free it up and it screws right out. Use a good tight fitting boxed end wrench. If you are able to get it out, throw it away and get new ones. Sometimes a very little bit of heat is helpful. Be real careful because of the rubber seals inside the wheel cylinders. I would only use a small propane torch. For what new cylinders cost though, CowboyBilly9Mile's tip is the best advice.
Old 03-27-2006, 06:40 AM
Bart99GT Bart99GT is offline
Bart99GT is starting off with a positive reputation.
If the flats are just rounded off, use the vise grip method. Though I would just change the wheel cylinders as suggested if the truck has a good number of miles on it. For less than $10 each it may not be worth the trouble to free those stuck bleeder screws.
Old 03-27-2006, 11:18 AM
Kijutsu's Avatar
Kijutsu Kijutsu is offline
Kijutsu is starting off with a positive reputation.
You can also temperature shock the bleeder screws. Get yourself quite a bit of water, and get a torch. Heat the sucker up and while it's still hot dump some water on it. That's what we did to my friend's F-150 bleeder screws. Works great. Just be careful you don't catch stuff on fire. It's probably best to take the wheel off. Also take note of what Dan Robertson said, be careful not to overheat it and mess up the rubber seals in the cylinder.
brake bleeder screw Natcox012 1987 - 1996 F150 & Larger F-Series Trucks 3 03-25-2015 08:57 PM
bleeding brakes RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 14 12-29-2014 03:41 PM
Leaking bleeder screw? FX4-350 1987 - 1996 F150 & Larger F-Series Trucks 24 12-30-2013 07:29 PM
bleeder screw stripped front mike L 1987 - 1996 F150 & Larger F-Series Trucks 10 09-13-2013 08:11 PM
Stripped brake bleeder bolt Vic_Young 2004 - 2008 F150 10 05-04-2012 01:39 PM
Tags
04, 2006, bleed, bleeder, brake, brakes, f150, ford, ranger, removing, screw, size, stripped, stuck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
