Wheel Hub Change - Brake Caliper Removal Tricks?
I am (or I was ) changing my wheel hub as my bearing is shot. I unbolted the calipers, but they would not come off - they seemed to be hanging up on something and would only move about an inch or so before hitting the obstruction.
I believe that the obstruction is somewhere near the centre of the calipers as I can move either end further than I can move the whole unit (like a fulcrum).
Is there a step that I am missing? I tried a search, but did not come across this issue in any threads that came up. From the threads that I read it appears that anyone who had an issue generally had fun trying to pop off the hub and/or rotors, so I am expecting further joys down the road.
... before I forget, it's a '99 F150 ext cab 4x4 w/ rear abs.
TIA for any help!
TIA for any help!
Racerguy
I will check that out as soon as I get home from work today.
7700Rob
A mallet? I had read about using one for the hub assembly, but did not want to risk it for the caliper ..... I will take down any ridge and maybe give it a few little whacks if it sticks after that.
Thanks fellas!
7700Rob
Thanks fellas!
