[PIC] CDR valve...how to remove?
You should be able to remove the manitfold inlet tube and rubber grommet by prying the CDR toward the back of the engine away from the manifold gently. The the CDR slides down into the valley pan tube, usually held in place by a clamp. The tube is held into the Valley pan by a ribbed base.......the tubes will get very brittle so use caution if you intend to remove it from the pan.
Do you know when to service your CDR valve?
All 6.9L and 7.3L diesel engines are equipped with a CDR (Crankcase Depression Regulator) valve. Even the new 7.3L Power Stroke is also equipped with the same valve. The CDR valve is one of the leading causes of head gasket failure in these engines. The CDR valve is responsible for controlling the pressure/vacuum in the engine crankcase, and seperating the oil mist from the air and returning the oil to the crankcase. The CDR valve should be serviced every second oil change or when signs listed below are seen.
When the CDR valve is not properly serviced, engine oil enters the air intake and is drawn into the engine. The diesel engine will burn this oil as fuel, however, it is heavier and thicker than diesel fuel and, having greater BTU output, causes excessive heat in the cylinder. Due to the intake manifold design, most of the oil will migrate to #7 and #8 cylinders; the last two cylinders in the rear by the firewall. The increased temperature here will cause the cylinder head to lift off the gasket and allow water or oil to leak out the back of the cylinder head where it meets the block.
To check your CDR valve, remove the air cleaner hold down bolt and inspect it. If the bolt is covered with engine oil mist, it's time to service your CDR valve! Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A or IH part #1805319C1
To service the CDR wash with a solvent, allow to dry, do not use compressed air to dry. There is a small hole in the CDR back cover, ensure it is clean and open. If black chunks of rubber are visible in the intake, on the screen then the rubber membrane has disintegrated, replace the CDR.
Powersroke if yours is turbo then the CDR valve should be on the valve cover I believe. Your turbo oil drain should go into the valley pan hole behind the intake where the CDR is normally on a non turbo. You may indead have an oil leak from the turbo seals and that would coat the interior of the turbo pipes/intake.
BCFord of you can afford it replace the CDR.........
IH part #1805319C1...........cheaper
Psalm116
10-28-2013 07:44 AM
ineedhelp92
05-04-2013 12:04 PM
