Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-26-2006, 01:20 AM
Boba Fett Boba Fett is offline
Boba Fett is starting off with a positive reputation.
Centerforce Install
Wanted to know if anybody had put in a Centerforce clutch in an Early Bronco. I built a new engine for my 67 and chose a Centerfore Dual Friction.
The engine works!! It's survived initial break in and moved a little under it's own power. Key here is a little.
Problem I am having is that I can't seem to get the clutch to disengage to shift in into gear properly. Fooled with it a little, but it just made it worse.
Do you need a special clutch fork when going from a 3-finger to a diaphram?
Anybody installed one? Any problems with adjusting the pedal?
If everybody else has had no problems, I know what's up. Or at least I am pretty sure what's wrong then.
  #2 (permalink)
Old 03-31-2006, 09:52 PM
1bad73bronco's Avatar
1bad73bronco 1bad73bronco is offline
1bad73bronco is starting off with a positive reputation.
In my old 71 F-100, i had a 302 and a 3 speed which is the same tranny as in the EB's. I converted from a 3 finger clutch to a diaphram style. All i had to do was adjust the clutch a little more with the adjuster rod... I used the stock fork so...
__________________
--'73 Bronco----302, 3 spd, D44, 9", Tru-tracs, Twin sticks, 5.5" National Soft ride coils, F-100 pwr steering, 35x12.50's, tilt column, hurst shifter http://classicbroncos.com/forums/ima...ilies/grin.gif
-'98 Ranger---- 4.0, Auto, 31x10.50's
  #3 (permalink)
Old 05-01-2006, 12:04 AM
I wanted to let you know how I made out. I called a couple of Bronco places and Centerforce and all and nobody really had the same problem, so I called ordered up a fork and release bar, the thing with the bullet on it that goes from the fork to the Z-bar.
Well once I got the new release bar the answer was pretty apparent, the bullet that hits the fork was totally worn down from years of use and about 3/4" shorter than new. Once the new relase bar was installed...... the clutch worked.
Wow!
I've been so busy with other stuff it really took me a while to get back to the Bronco.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
