Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
cat converter and lean codes
Old 03-25-2006, 04:23 PM
charlieh88's Avatar
charlieh88
charlieh88 is offline
5.4 2001 SVT Lightning has empty catalytic converters, will this cause a lean or rich code with the 4 oxygen sensors. If so is there any way around problem besides replacing converters.
Old 03-25-2006, 08:10 PM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
It won't cause a lean or rich code, because those codes are only set by the O2 sensors before the cats. It will set codes from the O2's after the cats though, for "inefficient catalyst" or something of that nature, because the cats are gutted.
If you live in an area that doesn't do smog testing, you can either get MIL eliminators, which take the place of the after cat sensors and stop the check engine light from coming on, or you can have the PCM reflashed, or get an Xcalibrator program that will ignore the secondary O2's.
http://www.mileliminatorsonline.com/ Check here for MIL eliminators.
wildabeast
1997 - 2003 F150
05-27-2010 09:31 AM
Fordzilla80
1997 - 2003 F150
05-19-2010 08:52 AM
tuckpete
New Member Introductions
04-13-2009 09:11 PM
donald burnash
Modular V8 (4.6L, 5.4L)
05-07-2007 09:38 AM
Truck Issues
03-26-2007 10:08 PM
Quick Reply: cat converter and lean codes
