Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 03-25-2006, 04:23 PM
charlieh88 charlieh88 is offline
Garage is empty, add now
charlieh88 is starting off with a positive reputation.
cat converter and lean codes
5.4 2001 SVT Lightning has empty catalytic converters, will this cause a lean or rich code with the 4 oxygen sensors. If so is there any way around problem besides replacing converters.
  #2 (permalink)
Old 03-25-2006, 08:10 PM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a good reputation on FTE.Bob Gervais has a good reputation on FTE.Bob Gervais has a good reputation on FTE.
It won't cause a lean or rich code, because those codes are only set by the O2 sensors before the cats. It will set codes from the O2's after the cats though, for "inefficient catalyst" or something of that nature, because the cats are gutted.
If you live in an area that doesn't do smog testing, you can either get MIL eliminators, which take the place of the after cat sensors and stop the check engine light from coming on, or you can have the PCM reflashed, or get an Xcalibrator program that will ignore the secondary O2's.
http://www.mileliminatorsonline.com/ Check here for MIL eliminators.
__________________
95 F150 XLT 4x4 Centurion CCSB Conversion, 5.8/E4OD.
04 Crown Vic Police Interceptor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
