How many miles on your 5.4? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 07-05-2006, 02:34 PM
NRAJOE44MAG's Avatar
NRAJOE44MAG NRAJOE44MAG is offline
NRAJOE44MAG is starting off with a positive reputation.
2,000 on my '05...
  #32
Old 07-06-2006, 10:42 AM
99ExpyProblems 99ExpyProblems is offline
99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.
126,000 on my 99
Replaced #4 coil 2x
Replaced Heater Core
Replaced Blend door
Replaced #2 coil
Replaced #5 coil
2 spark plug replacements - all 8 2x
ABS Wheel Sensor
Front End Rebuild
New front rotors - warped
Front Pads 2x
Rear Pads
broken shift cable
6 Disc DVD player won't eject
New transmission filter and fluid change
Replaced Fuel Pump
Replaced IAC valve
minor hose replacements
Except for the front end rebuild, I've done all the work!
  #33
Old 07-08-2006, 08:49 AM
Kevinpmac Kevinpmac is offline
Kevinpmac is starting off with a positive reputation.
Thumbs up
Now up to 144K and running strong!
  #34
Old 07-09-2006, 01:00 PM
caddys83's Avatar
caddys83 caddys83 is offline
caddys83 is starting off with a positive reputation.
114768 as of right now and yes its a 5.4L engine. crazy huh
  #35
Old 07-11-2006, 10:38 PM
8AteEight 8AteEight is offline
8AteEight is starting off with a positive reputation.
Just turned 102k on saturday on my 99 Expy 5.4.
  #36
Old 07-15-2006, 07:10 PM
THE KING THE KING is offline
THE KING is starting off with a positive reputation.
She broke on me today at 80 thousand Very upset
  #37
Old 07-19-2006, 08:04 PM
mingiz mingiz is offline
mingiz is starting off with a positive reputation.
2003 SD CC 4x4 59200 not problems at all.... But going diesel
  #38
Old 07-19-2006, 08:17 PM
arazor arazor is offline
arazor is starting off with a positive reputation.
Currently have a 99 F250LD 4x4 supercab with 89,000, had maf sensor changed and on the way home from dealer getting on highway put it to the floor and she shut off. pulled over and she started right up-took back to dealer next day after work, they pulled it right in and the mechanic came back and apologized for not finding bad cop and changed it in 15 minutes no charge-could'nt ask for more-milage about 13.5 no matter what I do.
had a 98 expy 2wd the wife drove with 118,000 we traded in and never had a tune up or problem other than battery change and still got 15-16 in town and 17-19 on highway and my wife is a LEAD foot.
I wish my truck was spunkier but that expy would move off a red light.
  #39
Old 07-23-2006, 08:45 AM
350z 350z is offline
350z is starting off with a positive reputation.
Thumbs up
04 f350 , 16,500 miles, 3 years old on 3/31/07, no problems .
  #40
Old 07-25-2006, 05:41 PM
vista461 vista461 is offline
vista461 is starting off with a positive reputation.
01 Screw 104K only problem was a blown out plug, which I fixed.
Had I changed the plugs at 100K instead of the remaining 7 @ 102K I wouldn't have had that problem either
  #41
Old 08-04-2006, 07:10 AM
speedysix speedysix is offline
speedysix is starting off with a positive reputation.
03 250 SD 94856 5.4L oil change only .going to replace all filter and fluid.sprak plug and brake pads this week.
  #42
Old 08-15-2006, 06:47 PM
aczr6 aczr6 is offline
aczr6 is starting off with a positive reputation.
70000 as of today
  #43
Old 08-19-2006, 07:49 AM
Modified 99 Modified 99 is offline
Modified 99 is starting off with a positive reputation.
1999 5.4 with 113K and going strong. Have a bypass filter system and engine oil cooler. trans cooler, K & N FPIK, Flex-A-Lite electric fans. All lubricants are AMSOIL including Differential.
Ford replaced both head gaskets at about 50k
Front brake pads twice
Changed trans fluid & filter once
Changed Diff fluid once
Flushed coolant system once
I did all myself except the head gaskets
  #44
Old 09-02-2006, 07:48 PM
Angler1979 Angler1979 is offline
Angler1979 is starting off with a positive reputation.
120,000 on my 2000 F250 SD 4X4
105,000 on my 2000 EB Expy 2x4
  #45
Old 10-15-2006, 06:22 PM
muddytires muddytires is offline
muddytires is starting off with a positive reputation.
I have 75,000 miles on my 2002 f-250 5.4 sd 4x4off road 4dr
How to delete thread Cpolinsky 1997-2006 Expedition & Navigator 1 03-23-2015 10:35 AM
How to lower a 92 F150?? 1987 - 1996 F150 & Larger F-Series Trucks 18 10-30-2010 04:41 PM
How to test FICM? KRDiesel 6.0L Power Stroke Diesel 2 07-29-2009 10:58 AM
hows the AC in a '96? colbyjames 1978 - 1996 Big Bronco 3 08-17-2008 08:09 AM
using photoshop stroken User Gallery & Picture Display 20 08-12-2007 12:26 AM
Tags
2000, 3valve, 54, 54knocks, delivery, engine, f250, f350, ford, miles, starting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
