Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-24-2006, 09:29 PM
f-61driver f-61driver is offline
Garage is empty, add now
f-61driver is starting off with a positive reputation.
1978 F61 vin needs decoded
I found a 1978 24ft U-haul. And I need the vin decoded. I think its a 477 but it might also be a 361 FT.
F61(K)VCG1003 K=477 right? Thanks Jason....
  #2 (permalink)
Old 03-25-2006, 06:34 AM
IB Tim's Avatar
IB Tim IB Tim is offline
Site Administrator
1989 Swift DB4
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
  #3 (permalink)
Old 03-25-2006, 09:48 AM
Exclamation
Any one with info... I want to make a run from TN to New York. Putting a full tune up on it. Ungoverned carb, plugs,wires,changing over to electronic ingnition,filters,fluids,and maybe a fuel pump for insurance. But I need to find out engine displacement. Vin# F61KVCG1003
  #4 (permalink)
Old 03-26-2006, 12:36 PM
Still in the 60's Still in the 60's is offline
Still in the 60's is starting off with a positive reputation.
All Uhaul Fords from that time I have seen were F-600s. I don't have the info to decode that, But an F-600 would not have a 477. I think it likely is a 330 medium duty, which of course was part of the FE family. I am guessing a 4spd tranny, single spd rear axle? The Uhaul trucks just weren't a heavy duty chassis. Hope this is some help.
  #5 (permalink)
Old 03-26-2006, 02:56 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Go here and look. Code "C", which is in your vin, is a 330 md 2bbl.
VIN is 17 digits.
Google "Ford VIN" and you will see the 17 digit and engine code at number 8 is the way they all are for Ford. I think you are missing some numbers in your first post.
A 330 makes sense for this type of truck.
Also, look in the FE threads and the SD threads where folks have described the FE. There is a certain number of valve cover bolts, the plugs ange one way, and the biggest item is the intake manifold goes under the valve covers.
There are also pictures of SD motors in the SD threads.
You probably have the 330 and if you do, you are a lucky dog....
  #6 (permalink)
Old 03-26-2006, 04:05 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
1986 Ford F-350
85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.85lebaront2 has a great reputation on FTE.
william.a.vose
On pre 1980 models, the VIN is only 10 digits. I don't have anything on the HD/SD identification. K is the engine code for 1978 being the 4th digit. Ford also used some unusual sounding engine sizes to differentiate between medium, heavy and super duty. The had such gems as 359,360 and 361 and 389,390 and 391. Chances are it should probably use Motorcraft BTF31 plugs or equivilant (don't use Champions, they revised their heat ranges). There may be a tag under the temp sender with the engine size, and if you are real lucky, a sticker on the left valve cover.
__________________
Bill Vose (Old School Hot Rodder)
1986 F350 crew cab DRW 460ci EFI, E4OD, PMGR starter, 160 amp 3G alternator, 12X3 rear brakes, Traction lock 3.55
1995 Lincoln Continental (project car), 1994 Taurus LX (daily driver)
http://www.oldschoolhotrodder.com
"growing old is inevitable, growing up is optional"
  #7 (permalink)
Old 03-27-2006, 07:30 PM
Thanks... There is a tag on the fender with the 330MD , 330HD,and 359HD for an original equiped engine displacement. The truck has a 4 speed with a two speed rear. Is the 330 a better engine for use? Like gas milage or reliability...
Tags
1978, 1980, 1985, 330, continental, engine, f350, f600, ford, lookup, number, numbers, pre1980, truck, vin, vin1978ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
