Edge owners: Tuning thread
#151
Originally Posted by dprince
hey i have been searching the intranet for tuners and i like what the edge has to offer but iam wondering is it worth it i recently added single dual exhaust and a k&n intake and was wondering is the edge worth it?? i do like the mounting option with the added gauges
#152
Originally Posted by 2004f1504X4
Apparently these trucks have a problem with hot climate. As for the fuel don't know but everything is possible!!, suspect the engine cooling needs improvement...may be these truck need extra fan. Any idea to add an extra fan is appreciated
Back to Edge, if I use 95 and the first time I connect the unit, should I adjust the settings for the fuel to match 95? how? and can you change the settings back to 91?
Also, I am really curious about the fuel setting in the stock program! is it 87, 91..?? How can I know before connecting the the EDGE?
Thanks!
Thanks!
#153
#155
If any of you are having an issue with high temps, be it boil over, or just the heads getting too hot and causing pre-ignition...there are products out there that will soften your water and allow for better heat dissipation. There are also a few gems in the bucket of dirt we call oil additives that actually make oil work better and run cooler.
Products I recomend are:
http://www.two2cool.com/products.htm
We do not carry this line. This product has a VERY loyal following in the 2-cycle motocross arena.
http://www.redlineoil.com/products_coolant.asp
We carry this line
http://www.royalpurple.com/prodsa/prpice.html
We carry this line
http://www.designengineering.com/
We carry this line
http://www.awdist.com/mohney.html
This is where I buy my Amsoil. This guy is an official in the Power Pulling Productions organization and very active in other competition truck pulling organizations. He is a truck lover and a performance addict....my kind of guy.
http://www.discountpowerparts.com/On...Treatment.html
This is the additive I personally add to my Valvaoline "Not Street Legal" 1.8% zinc race oil, and also what I add to my Amsoil 3000 Heavy Duty Diesel oil. If it came down to being able to run straight oil in my 8,100 RPM race engine alone...or urinate in the crank case and add MT-10 to the urin for lubricant... I'll take a gallon of water please, because I have a lot of pee'ing to do and a short time to do it!
If you combine a water wetting agent, a good oil, and an industrial oil additive that actually does what it says, you will see much lower cylinder head and water temps, less wear on bearings and rings (I have a race engine that went 4 years on a set of mains and rods with MT-10), and better general performance from an engine that is running more free, and cooler, with less wear and tear. I have Amsoil or Valvoline 1.8% zinc with MT-10 in every tractor, lawn mower, weed eater, ATV, car, truck and SUV around this place.
We carry this line
We carry this line
We carry this line
#156
edge
I am not the smartest at truck engines and stuff and i have been reading about yall changing the timing and things with the edge and i was thinking of getting the edge for my truck but i am not sure about changing the timing and shift point and things like that so if i get the edge will it do it or do i have to change it or what? I just don't wanna screw my truck up! I mean how do i know what to do once i get it? Also how does it mount to the dash of the truck and what color pod does it send with it? I just got my truck last thursday and its a southern comfort edition and the dash is black and dark gray just wondering how it will look with the color of my dash!
#157
Well there are a few regular settings that you can choose from that alter the timing. If you run any of those, you dont *have* to tweak anything. Provided you are running the correct octane for the settings, you wont have anything to worry about. Of course you can customize those tunes, but only if you know what you are doing (or ask here and find out). The pod that comes with the unit is black, so it will work with your dash perfectly.
Edit: Pictures can be found here http://www.discountpowerparts.com/On...ner_F-150.html
#158
welli was up until about 4am reading all your responses on the edge and well i think i made the right decision and bought one this morning at discountpowerparts .com paid extra for faster shipping. i like instant satisfaction!! but then relized i ordered on sun day so it will still take about 4 days oh well gives me more time to get excited thanks for all the info you guys provide in this forum
#161
#163
I would call Edge and ask about the E85 fuel. I did talk to Jet Chips about E85 with a Thermo master chip a customer wanted, and jet said the tunning was the same. So...maybe the Edge tunes have been tested and deemed good with the E85 fuel. It could happen.
The pod on the Edge is black and mounts with adhesive backed velcro. it is easily painted any color you wish an appropriate color of interior vinyl die that is available at your local auto parts store.
if you dont like the idea of the Evolution mounted to your dash, simply apply the tune and remove it from your dash.
#164
#165
