00 Expedition trans shifts late and hard
Hi all,
My 2000 Expedition started to shift into 2nd gear late and hard a few weeks ago. All other shifts are smooth and normal. The problem is only noticable when accelerating slowly. The truck has been driven for 75,000 well maintained miles. A trans flush has not helped. Any ideas?
Thanks, Pepster
Thanks, Pepster
I had a similar problem about two years ago when I had approx. 75000 miles on my Exp. I took it to a transmission shop that came very highly recommended by several sources including my mechanic. They determined that I had a broken spring in a valve modulator that cotnrols the shift from first to second gear. Anyway, $300 later the transmission worked fine and continues to work fine. I am now at 90000 miles.
Originally Posted by 98blueexpedition
Does anyone know if the transmission needs to be removed to fix the "broken spring in a valve modulator that cotnrols the shift from second to third gear?" Is it possible for a home mechanic to do this?
98blueexpedition, I have the 4R100 tranny and I also noticed in my previous posting that I should have stated second to third not first to second. The shop that did my transmission did not have to remove the transmission. From what the shop described, I probably could have done the job myself, however I don't like to waste vacation days on projects like that. For one thing I am not sure where I would buy an individual spring like that.
Since that transmission repair, I have had no further transmission problems. At the time, the shop owner knew almost immediately what the problem was. I now have 94000 miles on the Exp., don't drive it as much right now because the oldest one is in college and we use her car instead, but when I use the Exp it is to tow a boat or along one of the beaches on Cape Cod. I am due to change the transmission fluid with the next oil change and it will be interesting to see the condition of the fluid.
The first place i brought this problem to said i needed a complete Transmission overhaul. Well, they wanted over 2K to do the job. They never mentioned the valve body springs at all., or even investigating it. They charged me $90 for a bogus diagnostic. i would not use these guys again. They are .Smitty's Automatic Transmission Service in Wallingford CT
I brought it to a second place called Eastern Automatic Transmission in Wallingford CT. Mario diagnosed the problem to be the spring. Well $350 Later the transmission works perfect. That price included a transmission/torque converter flush too. Good Guys.
I called the original place back (Smitty's Automatic Transmission Service in Wallingford CT) to let them know what happened and they would not give me a break on the diagnostic fee. He said it was a Band-Aid for the main problem and he stands by his diagnostic. I think that is a load of BS if you ask me.
This site is great and saved me a ton of cash.
Thanks All.
Thanks All.
98blueexpedition, glad to hear that your transmission problem was not a major problem. Your results also give me a lot of confidence in the repair and transmission shop I have used in the last few years. I complain about the repair shop being somewhat expensive, however I have never had to return to him after a repair.
On another note isn't it amazing that Ford Motor Company cannot even design a compression spring properly. Another example are the suspension springs on the Taurus.
Goaltender46
1997 - 2003 F150
11-21-2011 10:54 PM
Ecarlton1991
08-05-2011 07:16 PM
pepster
05-28-2003 08:05 AM
