Rear main seal
You'll have to remove the transmission, clutch/torque convertor and flywheel. Get a screw(about a #8 sheet metal), drill an appropriate diameter hole in the face of the seal to thread the screw in. Take a pair of pliers, grip the screw and pull the seal out. Clean the mating surface good. Apply a thin coat of oil on the crankshaft flange and install the new seal. If it's the 2 piece, the the pan has to come off and the engine has to be lifted for that.
FordF350Baby
05-19-2009 08:05 PM
micah
02-12-2000 10:25 PM
