Updated turbo 390 pics.
Added a few more pics to the Turbo Project gallery. About 2 more weeks and it will be on the road. The motor has around 350hp alone. So adding the turbo (5-7psi)and having a 150 shot of nitrous should give it....well....I have no idea....anyone have guess? All I know is there is a very high possibility of getting this truck into the low 12's.
Any and all feed back is appreciated...
Scott
Scott
I'm going to guess between 500 and 650 horsepower, and more torque, depending on head flow, cam, and compression ratio. I think either the turbo or the nitrous would be ok alone, but those regular 390 blocks have a nasty habit of coming apart around 700ft-lbs. It takes quite a few passes for the parts to fatigue enough, but it does eventually happen. You would have been much better off with a 360 truck block.
It does look good though!
DieselRunner
05-16-2008 07:37 PM
390, block, charged, engine, fe, ford, pics, truck, turbo, turbocharge, turbocharged, turbocharger, turboed
