You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
i am about to change plugs in my 00 lightning, mods include diablosport predator, 90mm mass air, k&n cold air intake, and a flowmaster dual exhaust kit, question is what plugs to buy and what the correct gap should be. and does anyone have a step by step process on how to cahnge plugs on a 00 lightning?
I did not see a pulley listed in with your mods, so I'll assume you're running stock boost levels. The factory platinum plugs or NGK TR6s work well for your application. Might want to gap them around .041 to reduce the chance of detonation.
When adding extra boost, the rule of thumb is to squeeze the gap down .001 for each pound of added boost. The stock plugs are gapped at .042, so if adding a 4 lb. pulley, you'd want to gap the plugs at a tight .038
__________________ Ken Wilson
HALO Vice President "Anything less than a Lightning becomes prey"
403 RWHP / 518 RWTQ
According to that chart it says I should be gapping my plugs at .036. I have Denso's 22's and I gapped them at .032 that's with a port and a 6#er. If I gapped them at .036 I would be afraid of spark blow out.
If it idles and drives fine, then there is no need to open the gap.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
i have ported blower and six lb. lower and i gapped my denso 22s at 37. no problems with blow out.
I have a 2001 lightining low miles upgrades 6 lb pulley,shift kit ,programer chip,Electric fan .Question: plugs are stock need to change them out i was told to use a colder plug. any one have any good ideas on what plugs to use and gap. thanks.
