95 Bronco in line fuel filter quick disconnect question - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 03-23-2006, 09:59 PM
Alta's Avatar
Alta Alta is offline
Alta is starting off with a positive reputation.
So I thought Id do a little PM and replace the in line fuel filter on my 95 Bronco (351). The book wasnt clear on how the "quick disconnect" fittings disconnect and I basically ripped the old filter out of the fittings. When I did this some interesting little metal retaining pieces came out too - not without a little help however.
So now I have these quick disconnect fittings that the new filter just slides in and out of easily. I re-installed the metal clips that snap over the fuel line and fuel fitler tubes but these really dont look like they serve any purpose. Also the white plastic retaining clips that came with the filter seem equally useless.
So what Id like to know is did I destroy the quick disconnects or is there something Im missing about the plastic horse shoe shaped clips that came with the filter.?
Im feeling rather discouraged having been beat by a fuel filter and also taking a significant hit on the nose with a mag light in the process. Any help would be greatly appreciated.
Old 03-23-2006, 10:07 PM
okst1 okst1 is offline
okst1 is starting off with a positive reputation.
To remove the fuel filter, you are supposed to use an "air conditioner and fuel filter removal tool". I think you just cost yourself some big bucks to replace the fuel lines but I could be wrong.
Old 03-23-2006, 10:23 PM
yamaweezle's Avatar
yamaweezle yamaweezle is offline
yamaweezle is starting off with a positive reputation.
Quote:
Originally Posted by Alta
So what Id like to know is did I destroy the quick disconnects or is there something Im missing about the plastic horse shoe shaped clips that came with the filter?
the plastic horseshoe retainers are for a different type of fuel line fitting...the retainers you have are most likely ruined, since they require a special tool (which can be obtained at any auto parts store) to release them...i can't think of a fix for your present problem, other than replacing the fuel lines...maybe someone else has run across this, and has come up with something...good luck...
Old 03-24-2006, 03:22 AM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
You probably ruined the quick disconnect fittings. Ask Napa or a Ford service if there is a cheaper remedy than buying a full fuel line.
Old 03-24-2006, 08:38 AM
1pump 1pump is offline
1pump is starting off with a positive reputation.
[QUOTE]I re-installed the metal clips that snap over the fuel line and fuel fitler tubes but these really dont look like they serve any purpose.
Those are a safety thing that Ford added after some recalls back in the 80's. All they do is keep your fuel lines from spraying all over the place in the event of a connector failure.
As as far as the fittings go, you might have just ruined the garter springs. They're the same ones that A/C lines use, so most parts stores have them. Just get the right size. Cheaper than trying to replace a fuel line.
Old 03-24-2006, 10:26 AM
Alta's Avatar
sounds good - I'll track down the garter springs - Ive learned a lot on this little job - I dont know why they ad tocomlicate everylittl part on the vehicle - it is just a fuel filter! After rebuildng a dozen or so engines over the years, seting up diferentials, fixing transmissions, and dong frame up resoratons, I really thought I could handle a fuel filter....sheeeeeesh!
Old 03-24-2006, 10:37 AM
BroncoRoadKill's Avatar
BroncoRoadKill BroncoRoadKill is offline
BroncoRoadKill is starting off with a positive reputation.
Maybe while your at the parts store looking for the springs, get a ac fuel line disconect tool, but get the metal one that scissors for different sizes. Most cars use this nowadays.
Old 03-24-2006, 11:21 AM
poffutt poffutt is offline
poffutt is starting off with a positive reputation.
you can always buy some fuel line rubber tubing and some clamps and just rig it up.
Old 03-24-2006, 11:30 AM
IMHO, not a good idea. The fuel pressure is too high. The lines have to be crimped, kinda like a hydraulic hose.
Old 03-24-2006, 11:34 AM
Quote:
Thanks for that info. I didn't realize the pressure is that high... my bad!
Old 03-24-2006, 12:08 PM
Alta's Avatar
this thing actually has braided stainlss lines and fancy heavy duty high pressure connectors - looks like $$ to me but being who I am I went ahead and forced the issue anyway. Im on a mission to find garter sping clips now....I shall prevail!
Old 03-25-2006, 12:09 PM
Alta's Avatar
4 bux at napa and all is well...live nad learn. next time I'll use the tool that makes the quick disconnects quick disconnects - lovely system!
Old 03-25-2006, 07:13 PM
geoaigel geoaigel is offline
geoaigel is starting off with a positive reputation.
Spring in for some plier style tools, not the plastic cylinders that you have no leverage with.
George
Old 04-04-2006, 03:10 PM
Alta's Avatar
Since I'll own this and other fords with this system for the rest of my life I thiink I'll just do that.
RT
Old 08-21-2006, 10:59 PM
tomMig tomMig is offline
tomMig is starting off with a positive reputation.
doe s any body know if you can change the fitting that the filter goes into
Fuel Line Quick disconnect retainer spring Treacy 1987 - 1996 F150 & Larger F-Series Trucks 3 01-16-2015 07:36 PM
Quick connect fuel line at tank won't release PEG 1997 - 2003 F150 5 11-12-2014 01:27 PM
'92 In-Line Fuel Filter replacement advice needed. 92 Red F150 1987 - 1996 F150 & Larger F-Series Trucks 5 12-06-2009 04:43 PM
95 351 in line quick disconnect question Alta 1987 - 1996 F150 & Larger F-Series Trucks 10 03-26-2006 07:34 AM
Beware D.I.Y.'ers- changing your fuel filter may cost you 500 Hundred Dollars !!!!! FX4dude 2004 - 2008 F150 16 06-12-2005 06:38 PM
Tags
95, bronco, change, disconnect, disconnecting, filter, fuel, inline, line, lines, quck, quick, release, removal, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
