Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 03-23-2006, 06:25 PM
Swineren Swineren is offline
Swineren is starting off with a positive reputation.
Question Fuel Tank Selector Valve
I have an 86 F-150, 302 EFI, and I think my selector valve has gone bad. Unfortunately, I am un-able to find a replacement. It is a 6-port with the canister filter in the bottom and no electrical connections. Anybody have any idea where to find one or possible troubleshooting tips?
Thanks in advance
  #2 (permalink)
Old 03-23-2006, 09:40 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
Everything I can find for that year shows either a powered valve or a high pressure pump/valve combo.
__________________
Jared
The government said all my vehicle were too old to be clunkers
FTE Guidelines
  #3 (permalink)
Old 03-23-2006, 09:44 PM
doesn't that figure...I get the truck with the part that doesn't exist...
  #4 (permalink)
Old 03-24-2006, 06:39 AM
subford's Avatar
subford subford is offline
subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE.
By the way it is called a "Dual Function Reservoir" - 9B263 (base part number) and not a "selector valve". The "Dual Function Reservoir" is not electrically powered, it operates off the fuel pressure of the running fuel pump.
There's no "real" selector valve on 1990-1996 trucks. The older 1987-1989 and 1986 5.0L EFI trucks have a dual function reservoir mounted on the frame rail that acts like a selector valve. The Carbonated trucks 1985 and earlier 5.0L and 1987 and below 4.9L, 5.8L and 7.5L have a 6-way mechanical valve. The switch on your dash selects which fuel pump will be energized.
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #5 (permalink)
Old 07-25-2008, 01:50 PM
sckirklan's Avatar
sckirklan sckirklan is offline
sckirklan is starting off with a positive reputation.
Exclamation
This question comes a few years late but I'm of a similar position. However I was curious how exactly the switch selects either tank. I noticed I have a fuse for a tank selector but the back tank does not work regardless of fuse in or fuse out. Keeping in mind, I'm not asking how to fix my back tank, that's under control - funds allowing, I'd just like to know about this mystery fuse.
Thanks!
  #6 (permalink)
Old 07-25-2008, 04:45 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE.
What year truck and what type of engine (gas or diesel) do you have?
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
  #7 (permalink)
Old 07-25-2008, 04:56 PM
subford's Avatar
Quote:
Thanks!
The fuse holder position is for the motorized electric fuel pump selector valve/gauge.
You may not have a motorized electric fuel pump selector valve/gauge or it may be frozen in the front tank position.
__________________
subford@gmail.com
  #8 (permalink)
Old 07-26-2008, 02:42 AM
Orin Martin's Avatar
Orin Martin Orin Martin is offline
Testing Engineer's Theory
Orin Martin has a good reputation on FTE. Orin Martin has a good reputation on FTE.
The resevervoir mentioned is a vapor seperator but if it has 6 lines 2 fuel,2 return inlelts and 1 fuel. 1 return outlet it is a pressure switch valve with a diaphram on top used to channel return to correct tank and close off the tank not selected, this was activated by whichever primary pump in tank was selected by switch on dash directly. In my diag I would try to verify if one or both pumps in tanks operate when selected. If not why , inop pump in tank or both no electrical to either possible bad switch.
  #9 (permalink)
Old 07-26-2008, 04:03 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Fuel Tank Selector Valve - 1985/86 F150/350
This question comes a few years late but I'm of a similar position. However I was curious how exactly the switch selects either tank. I noticed I have a fuse for a tank selector but the back tank does not work regardless of fuse in or fuse out. Keeping in mind, I'm not asking how to fix my back tank, that's under control - funds allowing, I'd just like to know about this mystery fuse. Thanks!
Welcome to FTE
And the year is?
Please, when asking questions, list all the pertinent details: year, series, 2WD/4WD, engine size, etc.
Profile sez 1986: 1985/86 F150/350's have one or the other of the following:
E5TZ9189A .. Fuel Tank Selector Valve-3 Ports / Marked: E57B-9F271-AA.
or...
E5TZ9189B .. Fuel Tank Selector Valve-6 Ports / Marked: E57B-9F271-BA or E67B-9F271-AA.
Both these parts are known to fail without notice, and both are still available from Ford.
Normally I'd list the MSRP & the FTE member net prices, but FTEpartsguy.com's website is down for maintainance.
FTE members receive discounts on Ford parts from FTE Ford dealer parts dept. sponsors.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #10 (permalink)
Old 07-26-2008, 07:38 AM
subford's Avatar
or...
NumberDummy,
Is either one of these Fuel Tank Selector Valves mentioned the motorized electric fuel pump selector valve/gauge or just the 3-Port solenoid and the the pressure activated 6-Port valve?
__________________
subford@gmail.com
  #11 (permalink)
Old 07-26-2008, 08:16 AM
Ford Parts Guru
Prices: 1985/85 3 & 6 ported selector valves
Quote:
Originally Posted by subford View Post
NumberDummy,
The 6 port is just a plain old plastic valve, what the 3 port is...I can't tell, cuz the illustration on the microfiche slide is badly scratched and cloudy.
There's also the following used on one 1986 (302 w/dual tanks), and 87's and later: 9B263 reservoir & fuel tank selector valve.
The 6 ported variety has been a "best seller" for Ford since 1985.
I sold so many of those 6 port valves, I know the p/n by heart.
E5TZ9189A .. 3 Port Selector Valve / MSRP: $108.10 / FTEpartsguy.com price: $77.83
E5TZ9189B .. 6 Port Selector Valve / MSRP: $213.05 / FTEpartsguy.com price: $153.40
__________________
  #12 (permalink)
Old 07-26-2008, 08:47 AM
subford's Avatar
The motorized electric fuel pump selector valve/gauge was not used on the 302 or 351 in 86-87 that the fuse position in question was used for. It was just used on the 460 and Diesel trucks but maybe a different part on the Diesel trucks.
__________________
subford@gmail.com
  #13 (permalink)
Old 07-26-2008, 09:26 AM
Ford Parts Guru
Here is the 6 port selector valve application. I sold tons of these valves, and mostly for gas engines.
1980/89 Ford Light Truck Parts Catalog / Section 90 / Page 26.
E5TZ9189B .. Fuel Tank Selector Valve-6 ports
Fits: 1984 Ranger 2.3 gas / 1984 Ranger 2.3 diesel / 1985/86 Ranger V6 / 1985 E150/350; F150/350; U150: all 6 & V8 gas / 1985/86 E250/350; 1985/86 F250/350 (O8500 lbs.) 6.9 diesel.
Section 90 / Page 27.
F1TZ9B263B .. Reservoir and Fuel Tank Selector Valve / 1986 F150/250 302 w/dual tanks.
__________________
  #14 (permalink)
Old 07-26-2008, 09:38 AM
frank2008ford frank2008ford is offline
frank2008ford is starting off with a positive reputation.
88 F-250 Fuel selector valve
Hi guys, thanks for sharing your mechanical knowledge and expertise, it has helped people like me immensely.I have a 88 F-250 5.8 and after reading, I took your advise and removed the fuel selector valve, and low pressure fuel pump that wasn't working.
I connected to the high pressure fuel pump,drawing fuel from the midship .The truck has been sitting for at least four years without starting.I just finished reconnecting everything late last night and will attempt to start it today.
My truck no longer has the extra fuel tank, but the trucks in great shape with 80,000 miles on it. After reading about this trucks fuel system,it appears to be problematic anyway,so I wont miss the xtra tank.
  #15 (permalink)
Old 07-26-2008, 10:06 AM
subford's Avatar
Is the valve you are refering motor driven?
This is the one the fuse is for that the poster sckirklan was asking about.
Vehicle: 1985 FORD F-350 PICKUP
Engine: V8 7.5 Liter 4BBL
Universal 6 Port Valve; Motor Driven
__________________
subford@gmail.com
Tags
1985 , 1989 , 1997 , diesel , f150 , f250 , f350 , ford , fuel , mechanical , port , selector , switch , switching , tank , troubleshoot , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
