Fuel Tank Selector Valve
#181
Subford, thanks for the information. Can you tell me how the tank pumps are grounded? Had time today to do some poking around. I have the dash panel off and the selector switch hanging out ready to check with a meter next time it happens. Looks to me like the power comes from the pump relay to the center of the one side of the switch on a red wire w/yellow stripe, and goes out to rear pump on brown/white stripe. I know that the tank connector has 2 terminals for the pump. Where do they ground the motor? When it happens again, I can watch and see if there are volts going to the motor. If so, then it's either in the wiring, or it's the pump.
I'm still wondering why this didn't happen with the leaky front tank still there.
Thanks
Craig
Thanks
Craig
#182
#184
Gerry,
I'll flush it with diesel before shutting down each time. Hopefully that'll clean it all up.
Hey Subford,
Do you know if I have a six port valve? What's the best way to figure out which line comes from where? I'll also be hooking in a 12v heater/filter. Best place to draw power nearby? I know little to nothing about wiring, so any hints you have help me out immensely.
Thanks very much!
Hey Subford,
Thanks very much!
hey whisker subford is the expert on the dual function reservoir, but from his diagrams i have seen the insides of two of these parts and one of them was just this week after i retrieved it out of a junk yard for $5 yes i said $5 i got lucky they didn't know what it was. i told them it was a fuel filter. I think you might have a problem on the return because of the thickness of the bio diesel without being heated has a very small hole to go through. i say this because when I was cleaning out the rust on my first one with PB it was slow to come out of the return line that goes into the cap and back through to your tank. my suggestion would be to heat on both sides and flush it out with diesel. If you haven't seen the inside of one the hole is the size of a coffee stir stick. very small. that might be the only problem you face inside this part.
#185
#186
I have a 1986 XLT F150 4X4 dual tanks. I had a problem with my rear tank three years ago thought it was the Dual Function Reservoir. I un hooked the lines from the rear tank to the reservoir. Now my front tank is doing the same think sputtering when you try push down too much on gas. I took the reservoir off and it only has four lines to it. I took it and opened it up thought I would find a filter. I put the air hose to it and lines were clear. Now what? Should I just buy a new one?
#187
#189
#190
1986 F350 460
Subford,
I read the first 11 pages and didnt find a problem like mine.
I am having a couple problems with my (new to me) 1986 460 with dual tanks.
1) I have to shut truck off to switch tanks(cant do it on the fly) switch will move, it just wont draw from other tank till shut off and restart.
2) Gauge reads empty on rear, full on front.
Truck actually runs and operates fine minus those problems.
Previous owner installed a mechanical fuel pump said something about having issues with intank pumps. I dont know if the pumps are still in tank, hooked up, un hooked etc.
I, more than anything, just want my gauges to work, i figured maybe bad sender but wondering if it might be the valve?
Dan
Dan
#191
RockWVU,
As you know the selector valve changes the gauge from one tank to the other.
I would guess that the pumps are still in the tanks and the engine mounted fuel pump can pull fuel through the electric in-tank pumps. I know as I have kinda did the same thing with a 460. I would turn the in-tank pumps on with a switch if I needed them for going up steep hills, I have driven thousands of miles this way.
I would have no idea what he may have did to the wiring of this fuel system. Also I can not come up with why you would have to turn off the engine to change tanks.
#192
RockWVU,
#193
#195
