Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #76 (permalink)
Old 10-31-2009, 12:57 PM
80skeys 80skeys is offline
80skeys is starting off with a positive reputation.
Bill - I called my local salvage yard this morning and just asked if they had any 87-89 Broncos. They did, so I went and looked at it. In fact it had the reservoir so I purchased it and will be swapping it in today. Thanks for your help.
80skeys
  #77 (permalink)
Old 11-19-2009, 02:53 PM
Just an summary update on my fuel system issues, in case anybody cares.
My rear tank had sprung a leak and in the process of trying to get the gas out in order to patch it or drop it, it became apparent some crossfilling was going on. I could never get the damn thing dry, hence any attempts at patching were futile!
So at Bill's suggestion here, I decided the easiest and cheapest solution was to replace to dual selector reservoir with a single tank one. Nobody at the junkyard knew what I was talking about, so I had to go look under one of their old Broncos myself. Walah - there it was. I bought it for twenty bucks and installed it.
In doing so, the lines to and from the rear tank are left unconnected, which is what I wanted. I also disconnected the return fuel line on the passenger side of the truck going to the rear tank.
The end result is that gasoline is drawn only from the front tank. There must have been a little gas left in the rear tank, and I had to drive around for a few days to let it leak out and dry up. Finally it's no longer leaking and no longer smells of gasoline.
In doing all this troubleshooting, I've concluded that the gasoline system design on these older Fords is flawed and prone to problems. I mean, there's a low pressure pump in each tank whose purpose is to push gas to the reservoir. The dash selector switch activates the pump. The gas goes to the reservoir where it sits as a little reserve so that the high pressure pump has some gas to deliver in case the low one isn't primed. So the high pressure canister pulls gas from the reservoir. Then sends it through the filter. And then finally it gets up to the fuel rail. Whew! SEems like a whole lot of parts to do a simple task.
Well, a lot of people posting on these forums have reported the same issues with crossfilling, tanks not working, unable to select between tanks, unable to get accurate readings, etc...
I hope my description helps, and also Bill ("subford") is 100% expert on this stuff so anyone with problems - definitely should talk to him!
Tags
1985 , 1989 , 1997 , diesel , f150 , f250 , f350 , ford , fuel , mechanical , port , selector , switch , switching , tank , troubleshoot , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
