Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #31 (permalink)
Old 08-19-2008, 01:48 PM
subford's Avatar
subford subford is offline
subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE. subford has a great reputation on FTE.
Quote:
Originally Posted by sckirklan View Post
that connector is a pain to get to and it'd be easier for me to just stick a test prong on the wire from behind. do you think that should do just the same? seems to me shorting it is shorting it.
Thanks!
It also has to be open for the other side of the test.
open and then short
__________________
95 F150 302 4R70W EB EX-CAB
94 F53 460 E4OD COACHMEN SANTARA RV
83 F150 Flare Side 351W AOD
77 F250 351M-2V NP 435/4 Speed 4X4
subford@gmail.com
Bill K, Kansas Chapter
  #32 (permalink)
Old 08-19-2008, 03:01 PM
sckirklan's Avatar
sckirklan sckirklan is offline
sckirklan is starting off with a positive reputation.
I see. So then this should work, selector switch in the middle making no contact or on rear as my rear sending unit doesn't complete a circuit anyhow. That way I can keep from taking that plug back off. One of the retaining clips inside the plug broke and I have to mash one of the cables in after the fact. As brittle as this old stuff is, the least I can flex/strain it the better I'm finding out.
Thanks again Bill! Who knows, I may just pull the damn thing off and do it right anyhow.
__________________
1986 F-150 Longbed 4x2 302ci C6(fuel delivery FAIL)
2002 Bonneville 3.8l Series II (daily driver)
1986 Cougar 3.8l (retired)
1988 Thunderbird 5.0l (inverted landing)
  #33 (permalink)
Old 08-28-2008, 05:51 PM
sckirklan's Avatar
quick note-- i checked out the gauge last weekend and all is well... time to drop the tank this weekend and see if the float is fooy.
__________________
  #34 (permalink)
Old 09-03-2008, 09:07 AM
mankypro's Avatar
mankypro mankypro is offline
mankypro is starting off with a positive reputation.
ND,
Would you be kind enough to tell me how the 6 port on a 1984 f-250 4wd 6.9l diesel is switched? Mostly what I need to know how the oem tank selector switch is wired, as I want to use it to activate an inline 12v heater when I select my rear tank.
Thanks!
Quote:
Originally Posted by NumberDummy View Post
Welcome to FTE
And the year is?
Please, when asking questions, list all the pertinent details: year, series, 2WD/4WD, engine size, etc.
Profile sez 1986: 1985/86 F150/350's have one or the other of the following:
E5TZ9189A .. Fuel Tank Selector Valve-3 Ports / Marked: E57B-9F271-AA.
or...
E5TZ9189B .. Fuel Tank Selector Valve-6 Ports / Marked: E57B-9F271-BA or E67B-9F271-AA.
Both these parts are known to fail without notice, and both are still available from Ford.
Normally I'd list the MSRP & the FTE member net prices, but FTEpartsguy.com's website is down for maintainance.
FTE members receive discounts on Ford parts from FTE Ford dealer parts dept. sponsors.
  #35 (permalink)
Old 09-15-2008, 03:00 PM
sckirklan's Avatar
mankypro,
on page 2 of this post Bill has a nice image of how that selector works schematically. Basically if the switch is up, it uses the middle 2 and bottom 2 connections, and in the down it uses the middle 2 and top 2 connections if I recall correctly. Bill's draw up also has the wire colors marked so everything should become clear when you look at that plug and the wire colors.
__________________
  #36 (permalink)
Old 11-06-2008, 12:02 PM
AMSContr AMSContr is offline
AMSContr is starting off with a positive reputation.
fuel tank selector valve
I have an '88 F-30 dump w/dual tanks,7.5 EFI/460 and I am experiencing rough running mid-range under a load,hard starting when hot,check engine light coming on etc.etc. I have had the truck at the dealer timing set/checked,diagnosed and the cat checked out un-restricted. So my question is (before I risk any damage opening this fuel selector vave up) has anyone ever found a filter in one of these canisters?
  #37 (permalink)
Old 11-06-2008, 09:54 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of LxMan1 has much to be proud of
The Carb trucks use the electrically switched units from what I have seen.
AMS, no filter that I have ever seen, just a reservoir.
What codes are you getting? Fuel pressure when having problems?
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #38 (permalink)
Old 12-07-2008, 10:50 PM
MyOtherTruckIsAnFA18 MyOtherTruckIsAnFA18 is offline
MyOtherTruckIsAnFA18 is starting off with a positive reputation.
Indications???
What are the indications of a bad valve? Lately I can't start the truck because of fuel starvation and it seems that all of the fuel from the forward tank has been siphoned into the rear tank. I have been told that it could be either the tank selector valve (reservoir) or that one of the low pressure fuel pumps in the tank(s) are bad.
I have a 1986 F250 quad cab 6.9L diesel with dual tanks.
  #39 (permalink)
Old 12-07-2008, 11:03 PM
mankypro's Avatar
Powersmokes have in tank pumps, you don't. you have an FSV and a mechanical lift pump on the engine block.
Now, sounds like you have an FSV that has failed much like mine did. Meaning it's pulling fuel from one tank and returning it to the other. You can solve this by bypassing your FSV and direct piping to one or the other with brass hose barbs. Or you can drop the money needed for a replacement FSV. Fairly sure your FSV has failed mate.
  #40 (permalink)
Old 09-02-2009, 09:55 PM
200mphcobra 200mphcobra is offline
200mphcobra is starting off with a positive reputation.
Welcome to FTE
And the year is?
or...
NumberDummy could you elaborate on the discount for ford parts.........I happn to need a tank selector valve for a 1986 f150 5.0 with dual tanks.
Thanks
  #41 (permalink)
Old 09-03-2009, 07:27 AM
subford's Avatar
Quote:
Thanks
If it is fuel injected then the number is F1UZ-9B263-B.
If it has a Carb then it is one for three ports and the number number is listed above.
__________________
subford@gmail.com
  #42 (permalink)
Old 09-03-2009, 08:53 AM
It is indeed fuel injected, I replaced it once not knowing I could change the filter in it, this time the anti siphon valve pulled through it oring and is unreachable inside its "bore". The number on this one is F1TA-9B263-BA.
Stupidly I threw the original one away. I was interested in the discount for members from sponsored sites, as my local is over 100 bucks.
Thanks for the info.
  #43 (permalink)
Old 09-03-2009, 10:12 AM
subford's Avatar
The F1TA-9B263-BA is a drawing number and not a part number.
__________________
subford@gmail.com
  #44 (permalink)
Old 09-03-2009, 10:23 AM
Thanks again.
  #45 (permalink)
Old 09-03-2009, 11:46 AM
Quote:
Subford, you are very knowledgeable on ford parts, the number you gave me F1UZ9263B is about $70 online, while another part number I see for this application E5TZ9189B is about $150 online, is there a functional difference between the two? I know that my original had a filter inside of it, can that be the difference?
Tags
1985 , 1989 , 1997 , diesel , f150 , f250 , f350 , ford , fuel , mechanical , port , selector , switch , switching , tank , troubleshoot , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
