Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids and Mileage
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-20-2006, 08:14 PM
F250FarmBoy's Avatar
F250FarmBoy is starting off with a positive reputation.
how do i increase my MPGs?
I have a '89 f-250 with the 460/7.5 engine in it. I get about 10 mpg....bone stock. I was wondering what i could do to raise it by 2-4 miles to the gal....maybe. Also, money isn't an issue so gimme all you've got.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-20-2006, 08:38 PM
CowboyPenner's Avatar
CowboyPenner is starting off with a positive reputation.
This is a well discussed question but I'll give you a summary. Make sure you're tires have the correct air pressure....less resistance with the road and the engine has to work less. Use synthetic lubricants...again less resistance. Of course there are the mechanical mods like cold air intake to increase air flow into the engine. A high flow exhaust to match the increased air going in with the crap going out is also needed. On top of that a performance chip will help. The last step is a programmer to make sure the new bits and pieces are working nicely together. You can do any of these steps separately but for the best results all the steps needed to be packaged together.
I'm sure others will have more suggestions...spark plugs, plug wires etc etc.
__________________
Keith aka CowboyPenner
  #3 (permalink)
Old 03-21-2006, 07:32 AM
Greywolf's Avatar
"TROUBLE" with a keyboard
Greywolf has a brilliant futureGreywolf has a brilliant futureGreywolf has a brilliant futureGreywolf has a brilliant futureGreywolf has a brilliant futureGreywolf has a brilliant futureGreywolf has a brilliant futureGreywolf has a brilliant futureGreywolf has a brilliant futureGreywolf has a brilliant futureGreywolf has a brilliant future
An overdrive might help. Gear Vendors is one source, I forget who else makes them.
__________________
2008 FTE ANTIQUE and CLASSIC Truck Picture Contest
This is the place you have been looking for to fix your truck
  #4 (permalink)
Old 03-21-2006, 04:23 PM
it is a 5-speed w/ the overdrive
  #5 (permalink)
Old 03-21-2006, 04:24 PM
thanks for all the pointers. This should get me 1 or 2 more MPGs
  #6 (permalink)
Old 03-21-2006, 09:47 PM
Best of luck....let me know what your results are.
__________________
  #7 (permalink)
Old 03-22-2006, 05:02 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to allCowboyBilly9Mile is a name known to all
What axle ratio are you running, and do you do a lot of highway driving? I'll assume that it's currently in good tune and that you are not running an agressive off road tire. BTW, even BFG KO's result in a mileage hit, believe me from personal experience. Wider than stock tires also come with a potential mileage hit.
*Is your odometer accurate thus enabling you to calculate the correct mileage? Every now and then I read about someone that has put on larger diameter tires and *thinks* they took a mileage hit. Also, unless you have your foot in it constantly, you'll probably be dissapointed with mods that allow it to breath easier.
  #8 (permalink)
Old 03-22-2006, 06:51 AM
yeah,i do alot of highway driving to get to school. i dont know of the gear ratio but i'll check.
thanks again.
__________________
1985 F-350 6.9L -- dually -- ZF SF-42 -- 4.10 -- Flatbed
Dual ram intake/bucket seats/5" stack/manual GPs
  #9 (permalink)
Old 03-22-2006, 08:43 AM
tjc transport's Avatar
find me if you can!!!
tjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant futuretjc transport has a brilliant future
the easiest way to get better mileage is to cut off the right lead foot. by simply adjusting your driving habits you can easily gain 3-5 mpg.
__________________
Join me in the New Jersey Chapter, CLICK HERE!
NEW JERSEY CHAPTER LEADER
Tom
65 falcon 2dr h/t hot 289/C4
66 7 litre 4 speed convertible
79 F250 4X4 plow rig 351M C6
88 superduty diesel 4X4 C6 and banks turbo
99 crown vic P71 interceptor
02 F250 superduty diesel 4X4 stretchcab shortbox, all better now!!
  #10 (permalink)
Old 03-22-2006, 02:54 PM
Torque1st's Avatar
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Install a vacuum gauge and pay attention to it.
__________________
"Beam me up Scotty. There's no intelligent life down here..."
Eric
Tips & Tricks FAQ for 335 Series Motors
73-79 FAQ & Info
Garage Forum FAQ
For more info use PM.
  #11 (permalink)
Old 03-22-2006, 03:24 PM
Quote:
thanks again.
Remember, while numerically higher rear end ratios provide great torque multiplication, all of that engine reving consumes gas. Since you said money money is isn't an issue, the idea of a new ring & pinion with a numerically lower ratio comes to mind.
  #12 (permalink)
Old 03-22-2006, 07:00 PM
torque1st...what will a vacuum guage do for my MPGs?(stupid question)
__________________
  #13 (permalink)
Old 03-22-2006, 07:36 PM
Torque1st's Avatar
Posting Legend
It will make you keenly aware of when you are stepping on the pedal. That needle movement is the single best thing you can do to help you modify your driving habits which will net you more improvement than bolt on stuff.
__________________
Eric
73-79 FAQ & Info
Garage Forum FAQ
  #14 (permalink)
Old 03-22-2006, 09:16 PM
o...Ok i didn't really know what that was for. But now i do. Thanks i'll get one of them.
__________________
  #15 (permalink)
Old 03-25-2006, 01:59 PM
Bdox's Avatar
Iconoclast
Bdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant futureBdox has a brilliant future
You put that vacuum gauge in a prominant place on your dash where you can see it all the time. When you are driving, use your throttle foot to keep that gauge at the highest reading that is practical.
Also, run tall skinny high pressure tires.
Set your front end for zero toe and zero camber.
Get rid of big mirrors, bug shield, visor or anything else that creates drag.
Check to be certain that your brakes don't drag.
Run the lightest allowable lubricants in the engine, trans, transfer case and diffs.
If you have a rack or camper you can do without, get them off the truck.
Unload any extra weight you carry.
Consider a chin spoiler.
__________________
It's only kinky the first time you do it!
Life is short, make fun of it !
Bruce, Nevada Chapter
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
