Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Tennessee Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Tennessee Chapter Join Chapter Leader: Neal 97 250
  #1 (permalink)
Old 03-20-2006, 06:51 PM
jerryford jerryford is offline
Garage is empty, add now
jerryford is starting off with a positive reputation.
Question Is the dealer wrong
86 F150 4x4 302 FI 3:50 gears in the pumpkin 32x11.5x15 tires. With that info can anyone tell me if the dealer sold me the wrong gear for my speed sensor. The old one had 20 teeth and was black. The new one has 20 teeth and is orange. The speedo was correct before the old one wore out now with the new one it is 10 MPH faster. I called the dealer and told him this and he said that I had the correct gear. WTH???
  #2 (permalink)
Old 03-20-2006, 07:17 PM
Greywolf's Avatar
Greywolf Greywolf is offline
WILD CARD
1989 Ford Ranger
Greywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputation
The gear teeth are the same, so the ratio ought to be identical.
When were the tires added?
We looked at that at the Atoka G2G. If you go up in tire size, it DOES change the overall gear ratio back to front. Because the tires are a larger diameter, it throws everything off slightly.
It is also a logarithmic change - there is not much difference at 25 mph for example, but on my F100 with 33 inch swampers:
25 = 25
35 (on the speedo) = just under 40
55 = 60+
65 = 75 to 80 mph
The increased tire size means that you go farther with each revolution of the wheel. It also means reduced torque at the tire "Footprint", which was another point that came up.
I'm going to leave it to the brother who brought that one up to lay it out in a seperate thread....
A lot of great stuff was batted around!
__________________
Think outside of the box - especially if you built it yourself
  #3 (permalink)
Old 03-21-2006, 12:03 AM
maples01 maples01 is offline
maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.
My truck has 35x12.50's, upgrade from the origional 235/70's and it is 10MPH off, no way will you have it that far off with half the size jump, her Bronco II went from 205's to 31's and is 5MPH off. Are you sure the both have the same tooth count?
  #4 (permalink)
Old 03-23-2006, 06:58 AM
Yes both gears have 20 teeth the only thing I didnt check was to see if there was a difference in length of the gears or if the angle of the teeth were the same. Maybe the problem is with the dash cluster. mine has a tachometer so is there a formula that I can use comparing rpm to speed??? I was told by the dealer that you can check by going 60 mph for 1 mile and it should take you 60 seconds.
  #5 (permalink)
Old 03-23-2006, 01:54 PM
Greywolf's Avatar
WILD CARD
1989 Ford Ranger
Try this:
http://www.miata.net/garage/tirecalc.html
It's a page with an online tire size speed calculator.
There is also this:
http://www.tciauto.com/tech_info/speedo_gears.htm
__________________
  #6 (permalink)
Old 03-24-2006, 06:32 AM
lariat97's Avatar
lariat97 lariat97 is offline
lariat97 has a brilliant futurelariat97 has a brilliant futurelariat97 has a brilliant futurelariat97 has a brilliant futurelariat97 has a brilliant futurelariat97 has a brilliant futurelariat97 has a brilliant futurelariat97 has a brilliant futurelariat97 has a brilliant futurelariat97 has a brilliant futurelariat97 has a brilliant future
I wouldn't trust a local dealer around Memphis. I've had terrible luck with the ones I've tryed on parts. There right about 50% of the time.
  #7 (permalink)
Old 03-25-2006, 01:49 PM
westtntrucker's Avatar
westtntrucker westtntrucker is offline
westtntrucker has a very good reputation on FTE.westtntrucker has a very good reputation on FTE.westtntrucker has a very good reputation on FTE.
Stock Tire - 235/70R15 ..........................Tire 1 - 35x12.50R15
Section Width: 9.25 in 235 mm .................Section Width: 12.51 in 318 mm
Rim Diameter: 15 in 381 mm .....................Rim Diameter: 15 in 381 mm
Rim Width Range: 6 - 8 in Rim ..................Width Range: 8.5 - 11 in
Overall Diameter: 27.95 in 709.93 mm ...Overall Diameter: 35.03 in 889.76 mm
Sidewall Height: 6.47 in 164.33 mm ..........Sidewall Height: 10.0 in 254 mm
Radius: 13.97 in 354.83 mm ....................Radius: 17.51 in 444.75 mm
Circumference: 87.80 in 2230.1 mm ...........Circumference: 110.0 in 2794 mm
Revs per Mile: 744.1 ...............................Revs per Mile: 593.7
Actual Speed: 60 mph 100 km/h .............Speedometer1: 47.8 mph 79.7 km/h
Speedometer Difference: - Speedometer Difference: 25.33% too slow
Diameter Difference: - Diameter Difference: 20.22%
This was taken from this web site http://www.1010tires.com/TireSizeCalculator.asp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
