Nova Scotia Join Chapter, Leader:
List of things to fix
Old 04-19-2006, 04:16 PM
MatthewC's Avatar
MatthewC
MatthewC is offline
Just took the Bronco from J&P in Oromocto to my folks place. Dale gave him a look over and gave me a list of things he would like to see fixed.
Steering column loose
Pass. rear signal light fluttering
Shift indicator needs adjusted (wtf??)
Washer nozzel only sprays from one side (again, wtf)
Pass. emergency brake cable
Pass brake cylinder leaking
Pass brake hose retaining clip
Caliper bolt broken
Exhaust leak
Leak in gas tank
No problem. Will have to struggle putting a new gas tank in, but other than that, the rest is cake. On top of all that I have to put new brakes in the rear, a new core support on the front, as well as timing chain/gears.
Then stripping the interior, pressure washing the carpet, and Tremclading the whole floor as well as Krylon painting the interior trim to black.
Whew!
