Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-20-2006, 09:18 AM
bwhalen bwhalen is offline
Garage is empty, add now
bwhalen is starting off with a positive reputation.
1st step to increase HP?
Hello,
I have a 239 original flathead (F-5). Can you advise me on the 1st thing to do, to increase the power. I don't have $2 grand to sink into it. I'm looking for the most increase with the least money. One friend said a general overhaul. Another said change the heads. Do headers make much of a difference?
Thanks for your expertise.
Brad
Kentucky
  #2 (permalink)
Old 03-20-2006, 09:27 AM
sosotwo's Avatar
sosotwo sosotwo is offline
1948 Ford F-100
sosotwo is starting off with a positive reputation.
dual exaust worked for me
you might want to relive the block as well
  #3 (permalink)
Old 03-20-2006, 02:16 PM
Rancheroracer Rancheroracer is offline
Rancheroracer is starting off with a positive reputation.
If you rebuild it, put the Merc crank in it with a decent cam. I had a 239 with a Merc crank & 3/16" overbore, (286 ci). Ran very strong.
__________________
2012 F-150 XLT SC Ecoboost Tuxedo Black 6.5' bed 4x4
I can do all things through Christ who strengthens me. Phillipians 4:13
  #4 (permalink)
Old 03-21-2006, 09:19 AM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
Dual carbs and electronic distributor would bring up the performance. Also depending what trans and gear ratio you are running a 5 speed with 3.50 gears in the rearend might help.
Rod 51F1
__________________
Rod 51 F1 Truck
Flathead 6 / 3.23 Rear
S-10 5-Speed
"Keep on Truckin"
  #5 (permalink)
Old 03-21-2006, 02:33 PM
Thanks guys for the replys, and PLEASE keep 'em coming!
The reason I need the power is that I changed the original 6.66 rear end to a 4.11 posi trac. I was trying to get past 35 mph!, and the 4.11's worked, but I lost the power. The trans is still the original 4 speed.
Thanks again.
Brad
  #6 (permalink)
Old 03-26-2006, 02:52 PM
F6Guy F6Guy is offline
F6Guy is starting off with a positive reputation.
The best thing is a supercharger and a small four bbl carb with duel exausts. It sounds expencive but you can find kits for under 2 grand and it will be cheaper in the longrun than putting a merc long arm in there plus you can run up to 4 or 5 psi without going into the motor. Any more boost than that and you might want to put forged pistons and some valve springs in it. The bottom end should be good considering most of the stress it endures is from rpm and not compression. High compression heads lower air flow and limits cam lift. But a blower with good ignition and exhaust would work good for pulling with a stock heads and cam, considering its an f-5 I assume thats what you want to do with it. If your really on a budget dual exhausts, a small four bbl carb, and electronic ignition will help out alot. If you can swing it a good higher lift cam would be good too.
  #7 (permalink)
Old 10-21-2006, 02:16 PM
dffay dffay is offline
dffay is starting off with a positive reputation.
IF you elect to rebuild it. Have it balanced professionally. That is the single best thing you can do to the naked engine so it is not fighting itself. Thereafter, porting and relieving and some power adders like heads and such for bolt-ons as your budjet dictates.
  #8 (permalink)
Old 11-06-2006, 09:47 AM
SteV8e's Avatar
SteV8e SteV8e is offline
SteV8e is starting off with a positive reputation.
For better breathing, headers and dual exhaust will give you good value for your buck. Sounds good too.
__________________
SteV8e
1952 F3
Put this in your signature if you are a Christian with an Effie!
  #9 (permalink)
Old 11-07-2006, 03:12 PM
59INA40 59INA40 is offline
59INA40 is gaining momentum as a positive member of FTE.
Brad, back in the day when most rodders were on a budget, there were three things that they did to their flatties that returned the most bang for the buck. In order they are 1. Dual exhaust 2. Dual carbs and 3.mild cam. You can do all of these things yourself for under $500 if you are handy and don't have to have everything new. Or if you are like me, I have about $500 in the exhaust system alone due to the stainless Magna Flows that I couldn't live without. My flatty is lightly bored and displaces 250 cubes and with the above mods it is estimated that I am running about 130 HP (stock was 95HP). Steve
  #10 (permalink)
Old 11-07-2006, 03:30 PM
SteV8e's Avatar
Steve:
What do you recommend for the cam?
__________________
SteV8e
1952 F3
  #11 (permalink)
Old 11-07-2006, 10:11 PM
ksmith203's Avatar
ksmith203 ksmith203 is offline
ksmith203 is gaining momentum as a positive member of FTE.
I was wondering where the cheapest place to buy a rebuild kit at? I have a 226 flat 6 which I have ready to start rebuilding. The two place recommended so far are egge and kanter. Both place are around $1100.00 for the kit. Is there anywhere else that might be a little less? Not to take over the thread, but I have a 95 hp engine as well for a F-6.
  #12 (permalink)
Old 11-08-2006, 10:29 AM
SteV8e, I aquired an Isky solid cam from a friend of mine that replaced it with a 400Jr. Now he jokingly said he wants it back. He's got a '51 flatty that is displacing about 276 cubes and the thing will not idle very well but it gets off the line like nobody's business. The cam I have in my 59AB motor is a 77B. It's considered a mild street cam with good low speed and mid range power. I've had it in the motor since I rebuilt it 4 years ago and am very happy with it. Steve
  #13 (permalink)
Old 11-08-2006, 06:22 PM
Ksmith did you get the new pics I sent you?
Tags
flathead, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
