Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 03-20-2006, 02:25 AM
hawaiilightning1 hawaiilightning1 is offline
Garage is empty, add now
hawaiilightning1 is starting off with a positive reputation.
Why Engine Idle On My 01 L Sounds Weird
I have a 2001 L with these mods: Superchips micro-tuner, FIPK Filter, silver bullet exhaust system and a 8 lbs lower pulley change. My boost increased up to 21 psi but why is it when my needle hits to the top on my psi boost, the engine sounds weird. Sounds like its losing its power. Any suggestions would be appreciated. Could it be an adjustment on my speed limiter, or rev limiter? Please help....
  #2 (permalink)
Old 03-22-2006, 10:14 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
21psi???
Isn't that really high?
__________________
Justin
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
  #3 (permalink)
Old 03-24-2006, 11:04 AM
ace555's Avatar
ace555 ace555 is offline
ace555 is starting off with a positive reputation.
i really don't think u mean 21psi, remember stock is 8psi, but assuming you are running that much you need to tone it down a little. thats way to much boost for a stock L- unless you want to be replacing the bottomend soon
  #4 (permalink)
Old 03-24-2006, 07:50 PM
This started when I changed my stock lower pulley from a 2lb pulley to an 8lb pulley. I just said it could go all the way to max ps1. I have another aftermarket boost gage and it shows it goes all the way to 21 psi my max psi for this guage is 30 psi. It really produces a boost but when I floor it then that's when it starts a funny sounds like I'm flooding it or something. I wonder if it's just the speed limiter adjustment on my microtuner superchips......
  #5 (permalink)
Old 03-25-2006, 08:42 PM
mavman mavman is offline
mavman is starting off with a positive reputation.
Its the sound of your bottom end screaming for help!
Seriously, 21 psi? And you still have the (H)Eaton blower on it? Might want to re-think the combination there. Even at 14-15 psi, it makes plenty of power....but I wasn't aware that the hEaton blower was capable of moving that much air to produce 21 psi...at least not efficiently. You're probably pumping more heat than anything else.
  #6 (permalink)
Old 03-25-2006, 11:07 PM
What do you recommend?
  #7 (permalink)
Old 03-28-2006, 09:18 AM
The Swede's Avatar
The Swede The Swede is offline
The Swede is starting off with a positive reputation.
The Eaton S/C dont make more then 16 maybe 17 psi of boost. Sounds like you have a leak on a vacuum hose or one is loose somewhere. Check all your connections !
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
