Acetone in the water injection??? - Ford Truck Enthusiasts Forums
Old 03-19-2006, 11:39 PM
ckelly83 ckelly83 is offline
ckelly83 is starting off with a positive reputation.
I have read with interest alot on the subject of running acetone in the fuel tank (3 oz in 10 gallons) for better mileage, and a cleaner running motor. I am currently trying it for the first time in my 95 4.0L, 5 speed, Explorer to determine if I can achieve better than 18 MPG.
I have also read alot about water injection and it's advantages. What if the acetone was premixed with the water in the injection system to distribute the mix without running through all the components that could clog up with gunk like injectors, fuel pumps, filters, etc. etc.
I would run the water injection on my 83 F-150 with a 300 I-6, not the explorer because of excess spare room, and ease of working on it. Give me your thoughts, concerns, and opinions.
Old 03-20-2006, 01:12 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
why woud you inject water and acetone? the only thing you should inject is water and methonal.
Old 03-20-2006, 11:04 AM
sjser sjser is offline
sjser is starting off with a positive reputation.
Acetone in water injection
The acetone needs to be in the gasoline for it to do any good. Firstly, it cleans your injectors so they do a better job. Next the acetone reduces the surface tension of the gasoline, so the gas can be atomized into smaller droplets, which burn more completely - less into the converter & out the exhaust.
Expect it to take a few tank fulls to see results and don't overdo it or you will pay with your gas mileage (start out at 2 oz/10 gallons, track mileage & slowly creep up to see where your powertrain is optimized).
Don't expect to see great gains in gas mileage. My F150 got ~10% improvement w/a 302/auto/EFI.
Expect to see a potential dropoff in your gains after a while. Once your system's clean or your computer figures out what's up (not a clear reason why just yet) your gains may drop off - reduce your mix to maybe 1 oz/10 gallons or run acetone every few tanks or so rather than every one. My knowledge is a few months old so maybe peruse a few updated websites
Old 03-28-2006, 09:55 PM
73F100*8Mile 73F100*8Mile is offline
73F100*8Mile is starting off with a positive reputation.
what about adding acetone to a carb system? anyone ever experimented there?
Toluene as a diesel additive PSDLOVER 1999 - 2003 7.3L Power Stroke Diesel 4 10-12-2011 09:25 PM
50/50 Acetone/ATF 77FordDW 1973 - 1979 F-100 & Larger F-Series Trucks 12 05-03-2011 11:02 AM
Acetone Additive midapo General Diesel Discussion 9 09-09-2007 10:59 PM
New Recall 05E15 hbguy 6.0L Power Stroke Diesel 127 11-10-2005 08:12 PM
Fuel economy tip - acetone in fuel pcmenten Alternative Fuels, Hybrids & Mileage 21 09-14-2005 07:28 AM
Tags
40, acetone, acetonewater, asetone, explorer, f150, ford, gas, improves, injection, kit, mileage, motor, mpg, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
