replace ac condenser - Ford Truck Enthusiasts Forums
Old 03-19-2006, 04:37 PM
Mike8623 Mike8623 is offline
Mike8623 is starting off with a positive reputation.
I have a 96 f250 diesel and need to replace the ac condenser.......anyone ever done it themselves.........how hard is it..........some pointers maybe.........what about the connections?
Old 03-20-2006, 01:07 PM
hhott71 hhott71 is offline
hhott71 is gaining momentum as a positive member of FTE.
is it empty?
if not by the time you hassle with it, an AC shop can do the job and the few cents you might save won't be much.
If it is you will need springlock fitting tools. and servicing tools like a vacuum pump and gauges, and a charging cylinder to put the correct amount of R134a back in.
AC Replacement: Compressor & Condenser contramundum 1994.5 - 1997 7.3L Power Stroke Diesel 0 10-10-2014 11:51 PM
AC System Rebuild from Accident Island Time Cooling, Heating, Ventilation & A/C 2 10-07-2014 09:51 PM
2007 E450 6.0 PSD AC Condenser Replacement Chauncey237 Cooling, Heating, Ventilation & A/C 2 09-04-2013 06:23 AM
1996 F-350 a/c condenser housing insulation ruhlronnan Arizona Chapter 1 07-30-2013 04:23 AM
Condenser Oring rlt7272 Excursion - King of SUVs 0 02-18-2013 10:04 PM
Tags
2003, 96, ac, change, changing, condenser, condensor, condenssor, evaporator, explorer, f150, f250, ford, ranger, replace, replacing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
