Install the gauges yourself... Easy and save yourself about $200 (what most places will charge).
You dont need to add anything to clean your injectors... Run your truck and fill with clean #2. If you feel the need some power service is about the best thing.
Galazio,
If you think the injectors need cleaned try Hot Shot's Secret. It was designed for high pressure fuel injectors. It is worth the 50 bucks.
Chris
