You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Can anyone tell me on a 2001 ford lightning 5.4 supercharged where the rear pcv hose goes? Is it normal to hear air coming from lower back side of engine when i disconnect T fitting on pvc hose and blow air into rear pcv hose. If i do have to chage rear pcv fitting how do i get to it. My PCV lean rich gage is erratic and backfires above 3 K on tach, check engine light does not come on and a diagnostic shop said their are no codes>>
Its on back of engine block, to get to it pad radiator, stand on 1-2 foot step stool
take off any watches or rings, Remove dust cap from #1 side fuel rail and pad with rag, grease up left forarm with vaseline or grease, remove foam insulated tube from hard plastic PCV hose. My insulated tube came off in 2 pieces. Reach with left arm and follow hard plastic hose to rubber elbow. and check for damage. I hookep up compressor hose 4-5 psi and found no leaks on this hose and elbow. I learned the hard way about the time you feel rubber elbow, Empty kitty litter container kicks out from under your feet and the dust cap which i had left installed cut into my forearm. goodluck.
