Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-17-2006, 03:55 PM
ira551 is starting off with a positive reputation.
89Ford Bronco II Oxygen sensor 4 or 3 wire
I have a 89 Ford Bronco II project car with a 2.9 Fuel Injected engine. I just put a clutch in it and replaced the Y pipe along with the oxygen sensor. The oxygen sensor I took out was a 4 wire the one that I was sold was a 3 wire, when asked about the difference I was told all of them are now 3 wire. We started and test ran the vehicle, after running the codes it showed the temperature sensor was out of range and the Mass Air Change was bad. After replacing these two items it now says the oxygen sensor is lean(replace) does this have anything to do with 3/4 wire sensor. I called Ford and they said the 4 wire is obselete see if you can find one on the internet. Big help..The vehicle seems to fall on its face during acceleration, if you accelerate very slowly the engine seems to stay with you but if you get ahead of it, it seems to fall on its face some type of fuel issue ...... the Original Ford part number was F07F-9F472-DA Thanks Ira551
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-17-2006, 07:12 PM
Ken00's Avatar
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Welcome to FTE!!
The Ford wiring diagram for 1989 shows only 3 wires, o/bk for the 12v key on, dg/p to the ECU and bl/lg for ground.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
  #3 (permalink)
Old 03-18-2006, 08:48 AM
OSin86 is starting off with a positive reputation.
That 4th wire is just a chassis ground that the O2 sensor grabs from the threads now. Finding a 4 wire won't help your problem but you're new one my just simply be bad. Pull it, get a warranty replacement, clear codes and see what happens. Good Luck.
__________________
Current Rides:
'98 Ford Explorer Sport, SOHC 4.0, 2WD
'05 Chevy Colorado Crew Cab, 3.5L I5, 4WD
'02 Honda 400ex ATV, 11 herbs and spices
'04 Honda Recon ATV, The wife's trail machine
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
