98 f150 5.4 firing order - Ford Truck Enthusiasts Forums
Old 03-17-2006, 12:39 PM
mattbl mattbl is offline
mattbl is starting off with a positive reputation.
need to check or change the cop code says missfire on #3 cylinder. but not sure if it could be a plug or witch is #3. only had truck for six months 106 thousand miles on it. Shakes at 45 mph
Old 03-17-2006, 03:03 PM
Crush's Avatar
Crush Crush is offline
Crush is starting off with a positive reputation.
Mattbl,
Your cylinders are numbered from front to rear, with 1 thu 4 on your left (as your looking at the engine from the front) and 5 thru 8 on your right.
Crush
Semper Fi!
7.3? Vinford Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 11-02-2015 05:42 PM
The Family Jewels gus11208 1973 - 1979 F-100 & Larger F-Series Trucks 52 11-21-2010 03:42 AM
SF3 vs X3 tippmann87 6.0L Power Stroke Diesel 21 02-25-2008 04:38 PM
Value of 1949 F3 copeina 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 08-07-2001 05:48 PM
headlight fuse dust3 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-20-2001 08:21 PM
Tags
02, 1997, 1999, 2000, 2002, 2003, 54, 7700, f150, fireing, firing, ford, order, series, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
