Diagram or instructions for replacing door latch - Ford Truck Enthusiasts Forums
Old 03-17-2006, 09:12 AM
01f350 01f350 is offline
01f350 is starting off with a positive reputation.
I have to replace the door latch assembly on a 2001 explorer driver side door because the spring broke and you can't open the door from the outside. Does anyone know where I can find a diagram or instructions on replacing this? I know there are a couple rods that have to be disconnected and I figured if I had a diagram it would be easier. Should I pick up a repair manual or does anyone have an experience with this they can share?
Thanks
Old 01-14-2007, 07:52 PM
RCWMTW RCWMTW is offline
RCWMTW is starting off with a positive reputation.
I know this is an old thread but I have the same question
Old 01-14-2007, 09:22 PM
kevin74656's Avatar
kevin74656 kevin74656 is offline
kevin74656 is gaining momentum as a positive member of FTE.
Here is the R&R procedure for a '96 Ex from the Ford factory manual (on DVD). I'd be surprised if the '01 models differered much or at all from the '96.
There are some diagrams on the DVD. If you send me a PM with your email address, I'll send them to you.
Kevin
Latch, Door
Front, Explorer
Removal
Remove the front door trim panel and watershield from the front door. Refer to Section 01-05A .
Remove front door latch remote control and link (21818). Disconnect front door latch actuating rod. Disconnect front door latch control cylinder rod (22134) from lock cylinder.
Disconnect front door latch push button rod (21852) and front door latch control cylinder rod from front door latch (21812).
Remove the front door latch attaching screws. Remove the front door latch from the front door.
Installation
NOTE: Remote control rod and lock cylinder rod should be attached to front door latch before front door latch installation.
Install the rod retaining clips in the newfront door latch.
Position the front door latch in the front door. Install the latch attaching screws. Tighten screws to 4-8 Nm (36-70 lb-in).
Connect the rods to the handle, lock cylinder and remote control.
Connect handle rod and push button rod to front door latch. Check the operation of the front door latch.
Install the watershield and front door trim panel on the door. Refer to Section 01-05A .
Old 01-15-2007, 08:05 AM
Thanks, PM sent
Old 01-16-2007, 11:22 PM
kevin74656's Avatar
Quote:
Originally Posted by RCWMTW
Thanks, PM sent
Didn't get your PM, not sure why....give it another try.
Altman latch hooking up inside door handle question Bluey Zedoff 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 09-29-2014 08:24 PM
2001 F550 Door Won't Stay Closed phxfirefighter 1999 to 2016 Super Duty 2 04-09-2014 10:20 PM
Broken Door Latch???? E150 1968-2013 Full Size Vans 5 09-28-2013 12:23 AM
Need pics/diagram of F600 door handle and latch bulletsneverlie 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-17-2009 03:07 PM
Door latch removal instructions 40hotrod 1947 and Older Ford Trucks 6 08-03-2005 02:46 PM
Tags
1995, 2002, 21812, assembly, back, bronco, diagram, door, explorer, ford, ii, latch, lock, replace, sport, track, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
