oil sending unit ?
Old 03-17-2006, 07:53 AM
acourt's Avatar
acourt
acourt is offline
oil sending unit ?
hi, A few times over the past few weeks upon starting my 2001 f-150 the oil pressure guage drops to to the lowest position and the red oil temp light comes on at same time.This only happens after truck sits over night.I shut her off right away then restart and same thing happens upon 3rd restrart all is normal.oil leval is fine but i have noticed a higher than normal usage of oil (about one quart in 600 miles) lately but am not dripping any on the driveway.Could these two problems be related and where the heck is the oil sending unit located on the 4.6? Thanks for everyones help,Andy
Old 03-17-2006, 08:03 PM
Grsyhands's Avatar
Grsyhands
Grsyhands is offline
A qt/600 miles is not a good sign but...
How many miles on the truck and what have you been using for oil?
Old 03-18-2006, 07:12 AM
acourt's Avatar
acourt
acourt is offline
112000 miles,5-30 high mileage castrol,plugs have never been changed
Old 03-18-2006, 07:36 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Replace your oil sending pressure switch. It screws into the oil filter housing.
Oil consumption rate is getting up there, do keep an eye on it. Probably worn rings.
Steve
Old 03-18-2006, 09:52 AM
acourt's Avatar
acourt
acourt is offline
worn rings
how big a job is repacing the rings$$$$$$$
Old 03-18-2006, 10:42 AM
mdjohnson's Avatar
mdjohnson
mdjohnson is offline
A ring kit + labor, your looking at several grand. I know on a friends car his PCV valve was bad and it went through a lot of oil. Put a new PCV valve on and no more oil consumtion.
Do you have black smoke out of your tail pipe? Deos it leak any oil? If so, where is it leaking?
Old 03-19-2006, 05:52 PM
acourt's Avatar
acourt
acourt is offline
oil consumption
No does not leak oil to ground, i will have to check on the smoke,thanks
Old 03-19-2006, 06:12 PM
Bob Ayers's Avatar
Bob Ayers
Bob Ayers is offline
Changing the PCV valve is a good idea. Besides the rings, the next thing that will cause oil consumption are the valve guide seals. If the valve guide seals are bad, you will get a puff of blue smoke (NOT BLACK AS PREVIOUSLY POSTED) when you first start it after sitting overnight. So, have somebody
watch your exhaust, after sitting over night.
Old 03-20-2006, 12:01 AM
Grsyhands's Avatar
Grsyhands
After changing out the pcv, your next step would be a leak down test. If you're lossing oil via the valve guides, or valves, or rings, I would think it would show up as a decrease in compression somwhere. This would show on a leak down compression check.
With 112K, if the oil has been done regularly with the 5-30 you mentioned above I would'nt think it's related to valve seals, valves, or rings. However there has got to be some reason you're using a qt/600 miles. How hard on the gas peddle are you?
Old 03-20-2006, 05:28 AM
Bob Ayers's Avatar
Bob Ayers
A leak down test will test for ring or valve problems, but not valve guides & valve guide seals.....
Old 03-20-2006, 05:47 PM
Grsyhands's Avatar
Grsyhands
Right Bob. Got a little carried away.
Old 03-21-2006, 05:09 PM
nascar88ford's Avatar
nascar88ford
nascar88ford is offline
We have a 1997 F-250 LD and every once in a while when we go out to start it a cloud of blue smoke occurs. It doesn't do it all the time. It doesn't use any oil either. Should we be worried? I've notice my F-150, my step mom's Taurus, and my sister's Taurus do this also.
-Matt
Old 03-22-2006, 06:20 AM
projectSHO89
-Matt
That puff of blue smoke usually indicates the valve guide seals are leaking.
This is a pretty minor annoyance for the most part. Oil consumption due to this is not very significant until the problem gets really bad.
Steve
1978Crew
10-06-2010 10:09 AM
Darthange
1997 - 2003 F150
12-09-2008 10:57 AM
V8 Andy
10-21-2004 12:57 AM
AggiePSD
13
07-28-2002 05:45 PM
paulbrianstenhouse
04-06-2000 06:02 AM
Quick Reply: oil sending unit ?
