Today I cleaned the EGR passages on my '97 Expy 4.6L
EGR Passages
Just was wondering if you pulled the rigid hose between the EGR and the manifold as well. When I cleaned my '97 F150 4.6l's EGR and throttle body, I found that I needed to pull this as well since it was clogged. I ended up using a 12 guage shotgun bore cleaner to get it cleaned up.
The gunk in the throttle body was extremely hard like you said, I even had to get a drill with a drill bit after it to break it loose. Completed it two years ago, no more check engine light, idles smoother, and the gas mileage went back up. I did that at 100,000 mileas, and it now has 162,000 on it and my son still drives it daily and not a bit of problems. I'm glad you posted pictures, I did not have the forethought to take any, and it sure would have been easier for me when I was putting it back together.
Even though the pictures don't reflect it, I actually removed the EGR valve, to clean all the old gasket material off. This particular EGR valve is only about a year old, & the EGR pipe itself was never clogged. For whatever reason, the carbon blockage was confined to the throttle body only.
Originally Posted by ford390gashog
this buildup is known by ford as a issue. this is why they came out with the 929a and 930a spec oils. it almost eliminates it.
FWIW, I'm currently running Havoline synthetic 5w30. Do you think that synthetic oils would reduce this carbon clogging problem even better than oils that meet the 929a & 930a specs?
lwong
Oil & Lubrication
125
04-19-2005 02:27 PM
