Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Arkansas Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Arkansas Chapter Join Chapter Leader: tojoski
  #1 (permalink)
Old 03-15-2006, 06:30 PM
Ozark Ford_1970's Avatar
Ozark Ford_1970 Ozark Ford_1970 is offline
Garage is empty, add now
Ozark Ford_1970 is starting off with a positive reputation.
Sanding
Any one have an idea about the cost of having my 1970 F-100, long bed either sand blasted or sanded. The paint that is on there now is terrible.
__________________
Larry In La Vista, Nebraska----'70 F100 & '96 Explorer
  #2 (permalink)
Old 03-15-2006, 07:02 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
It would depend on the body man's rates. I don't really know what they make, but 10 years ago the premium body guys were getting $100/hr. or better. I would imagine the prep work of stripping the old stuff would be a good bit less than that since the paint guy would farm that out to the hired help.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #3 (permalink)
Old 03-15-2006, 08:54 PM
jimkidd's Avatar
jimkidd jimkidd is offline
jimkidd is gaining momentum as a positive member of FTE.jimkidd is gaining momentum as a positive member of FTE.
If you had an air compressor you could rent a sand blaster and DIY
jimbo
__________________
WANTED: Someone to go back in time with me. You'll get
paid after we getback. Must bring your own weapons.
Safety not guaranteed. I have only done this once before.
www.jimkidd.com
  #4 (permalink)
Old 03-16-2006, 12:59 AM
Ya' I have to figure out how I am going to get this paint off.
Thanks for the reply.
Larry
__________________
  #5 (permalink)
Old 03-16-2006, 11:12 AM
bhodgin's Avatar
bhodgin bhodgin is offline
bhodgin is starting off with a positive reputation.
Sand blasting creates pits and I would not recommend that but my cousin has a chevy he had bead blasted for a couple hundred dollars in NW Ark
__________________
Buckle up I wanna try somethin'
  #6 (permalink)
Old 03-16-2006, 02:53 PM
Quote:
Do you know the name of this place?
__________________
  #7 (permalink)
Old 03-16-2006, 03:09 PM
1996pwrstrk's Avatar
1996pwrstrk 1996pwrstrk is offline
Wrench Party Assistant
1999 Ford F-350
1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.
If you are going to have the complete body done I would suggest media blasting because sand ,even bead blasting ,creates heat that will distort your sheet metal. The media blasting uses plastic or sometimes crushed walnut shells and doesn't heat up. I don't know of any place to get this done here but I will ask around.
Dave
__________________
Dave
1999.5 F350 XLT,cc,drw,4X4,a pair of levers,4:10 LS
6637 mod, 4"MBRP cool duals,2 pos chip, ss hpx,ITP pre-pump with holley red pump ,140 V IDM , WW, EBPV deleted,AIH deleted, Autometer gauges
Join the Arkansas Chapter Here
  #8 (permalink)
Old 03-16-2006, 03:17 PM
Quote:
Dave
Thanks Dave.
Larry
__________________
  #9 (permalink)
Old 03-17-2006, 06:26 PM
bhodgin's Avatar
he said there was a place called waynes sandblasting that did it in springdale but isnt sure if its still around
__________________
  #10 (permalink)
Old 03-17-2006, 06:30 PM
Thanks. I will check. I am only about two hours away from there.
Larry
__________________
  #11 (permalink)
Old 04-03-2006, 03:06 PM
mechmagcn's Avatar
mechmagcn mechmagcn is offline
Diesel Junky
1953 Ford F-100
mechmagcn has a good reputation on FTE.mechmagcn has a good reputation on FTE.
Yes, sandblasting will distort metal, and it will also find every thin spot of metal on the truck also (I really don't want to tell how I know)
Jeff
__________________
Jeff
1953 F100 PU "Someday"
Lincoln Town Car front clip
5 cyl Mercedes turbo diesel/auto
It Runs! It Even Moves!
  #12 (permalink)
Old 04-03-2006, 09:17 PM
Lightbulb Thanks Jeff:
Quote:
Jeff
Thanks for the heads up Jeff. Bet I can guess how you know!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
