Nebraska Chapter Join Chapter, Leader: 97nukeford
6.0 PSD Fuel Filters
Old 03-14-2006, 08:26 AM
CBSuperduty's Avatar
CBSuperduty
CBSuperduty is offline
OK since I am not the only 6.0 guy here anymore I will share a little wisdom that will help on your wallet....
They say you should change fuel filters every 15K on these rigs. I am told that Ford wants $75.00 - $85.00 depending on where you go. I did price them at Advanced Auto (just happened to be in the area when I thought about it) and it was around $80.00. I have since found out, that if you go to an International Dealer (I went to Cornhusker International on 108th & L St.) you can get the kit for $35.04 (with tax) out the door and cheaper if you know someone with an account. This is for the kit which is 2 filters (1 with aquablock around it) and 2 O rings. Ford buys the VT365 motor from International but uses a fuel filter system from a VT275 (4.5L).
Racor #: 32442C93
International #: 1847170C92
Also, here is the procedure to change the filters. You will need a 36mm socket (which you can also use for the oil filter) for the bottom filter. I didn't have one so I still need to pick one up and change the bottom filter.
Hope this helps you guys.
Old 03-14-2006, 03:32 PM
67nukeford's Avatar
67nukeford
67nukeford is offline
Thanks CB! Good info.
Old 03-15-2006, 03:08 PM
CBSuperduty
No problem. I just like saving $40.00 per change.
Old 03-15-2006, 03:09 PM
67nukeford's Avatar
67nukeford
I hear that!
KLINE925
04-03-2014 01:29 AM
phantomphixer
11-13-2012 06:04 AM
bismic
08-14-2012 07:11 PM
BLADE35
02-27-2011 09:47 PM
Frankenbiker
04-22-2010 06:30 PM
Quick Reply: 6.0 PSD Fuel Filters
