DELUXE GreaseBeast FILTER KIT & Pump! SVO Biodiesel WVO
http://cgi.ebay.com/ebaymotors/DELUX...QQcmdZViewItem
Has anybody bought or used this? if so what are you using for fuel filters? What kind of setup are you running to heat your tank?
Look real close at what the questions are and the design. If you look close you can see the filter can is that of a pool pump canister. You can put this system together. Your in clevland. TSC will have the canister filter deal for fuel/ oil 27 bucks, the pressure guage you can find at true value hardware for 12 bucks approx. The heavy screen filter that can go inside the clear canister is 5 or 10 buck I cant remember. And additional filter that looks like an oil filter is also a TSC (tractor supply) or any other agg store. That is about 20 bucks and you can buy all the filters for 3 to 5 bucks and run 50psi through them. Youll have to shop. But this is just a fancy way to suck oil, if you make you own bio you wouldnt need this except on you final filtering before you put it in your tank and only then would you need the 27 buck filter setup.
Pool filter and pool pump canister
Pressure Guage
Heavy screen filter inside a clear Canister
I don't see where you have a way to filter out the water? they have a specail filter for the water which is very important to filter. I am a little unclear how I could DIY as good as package please explain as the cheaper the better this specfically for WVO
Trigun,
No filter made will filter water from WVO except free water. And that really does not need filtering since it is heavier then WVO and will settle.
I agree cmpletely with Kennedyford. You don't need much money to filter WVO. All you need is a cheap sock filter (about 6-7 bucks) a 55 gallon drum and time. A little heat helps to speed things up. Like keeping the WVO @ 90F or so for a few days will help any suspended water settle.
Originally Posted by trigun7469
http://cgi.ebay.com/ebaymotors/DELUXE-GreaseBeast-FILTER-KIT-Pump-SVO-Biodiesel-WVO_W0QQitemZ4611746273QQcategoryZ6755QQrdZ1QQcmdZ ViewItem
Originally Posted by leskwvo
Trigun,
There is no good answer to this. Prepairing the WVO for use takes time. It should never be done in a hurry. Things will start breaking if you start taking short cuts.
Some folks filter and settle into 5 gallon pals. But it needs to settle and it is best to keep it the WVO at about 90F while it is settling.
WVO my not be for you if you don't have the space to do it correctly.
Im back in town so I can reply to that first question. Trigun, if you go the the agg. store youll see what I mean by those filters. They do seperate water but only heavy amounts. Once again the micro small suspended water has to settle. If only you had the room then you could do some larger quantities.
Loxley
Bio-diesel, Propane & Alternative Diesel Engine Fuels
07-05-2016 11:21 AM
Eallend7
43
11-09-2015 11:05 PM
mongo75
19
03-17-2007 09:53 PM
parkland
17
03-27-2006 03:02 PM
