Radiator flush... - Ford Truck Enthusiasts Forums
Radiator flush...
Old 03-14-2006, 10:59 PM
Patatoe1's Avatar
Patatoe1 Patatoe1 is offline
Patatoe1 is starting off with a positive reputation.
Radiator flush...
I have a 01 F-150 and I want to do a radiator flush. How do I go about doing this the correct way.
I was told that there should be a drain on the bottom passenger side of the radiator. After draining that I was told to put a hose in and just leave it on for awhile to clean it out.
Would that be the correct way to flush the radiator?
How much new fluid would I need? And are there different types of fluid? If so which one?
Old 03-14-2006, 11:17 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
you simply remove the lower radiator hose . then you can flush it. i remove the heater hose and attach the garden hose right to the hose barb sticking out of the manifold where you just removed the heater hose from.
Old 03-15-2006, 07:28 AM
insp09 insp09 is offline
insp09 is starting off with a positive reputation.
I used about 2 gallons coolant and 1 1/2 gallons distilled water. What color coolant does it have now? When you flush, don't forget to turn the heater on to HOT.
Old 03-15-2006, 05:38 PM
Patatoe1's Avatar
With the truck off correct?
Old 03-15-2006, 10:01 PM
fbodyfan fbodyfan is offline
fbodyfan is gaining momentum as a positive member of FTE.
Don't remove lower radiator hose, there is a plastic valve located by the passenger front wheel. Where exactly I don't remember, but put a 5 gallon bucket under it, and you'll be fine. Leave the truck off. When it is all drained, close the valve and fill the entire reservoir with water and run for 15 minutes. Drain this water in to the bucket, and proceed to close the valve and put in your 50/50 mix of water and coolant. Make sure you don't let the family pet get a hold of that coolant bucket, its pretty toxic stuff.
Old 03-15-2006, 10:18 PM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.
I've used those Prestone kits with good success. My Ford tech buddy says they actually do a pretty good job.
Mike
Fuel Cooler Flush GHeTTo JOe 6.4L Power Stroke Diesel 3 12-13-2012 05:21 PM
2001 Expedition cliffhanger45 Expedition & Navigator 9 07-02-2011 04:09 PM
302 f150 flushing cooling system tom302 1987 - 1996 F150 & Larger F-Series Trucks 11 09-10-2010 09:49 AM
antifreeze in transmission fluid wjeffofl Aerostar 6 06-30-2006 02:52 AM
draining the engine coolant websthes 1987 - 1996 F150 & Larger F-Series Trucks 3 06-20-2005 09:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
