Offroad & 4x4
divorced vs married
Old 03-13-2006, 10:04 PM
chrono4's Avatar
chrono4
chrono4 is offline
divorced vs married
what are the pros and cons to running a divorced vs a married? only one i can think of is better front d shaft angles.
Old 03-13-2006, 10:17 PM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is offline
Its Comin Right for us!
Received 1,433 Likes on 936 Posts
pros for married, one less driveshaft, takes up less room underneath,
cons, short front shaft
pros for divorced, better shaft lengths/angles, can be dropped down for better driveline angles, easier to drop tranny and or t-case
cons, less ground clearance, one more driveshaft that can break, longer front shaft can hurt you depending on vehicle its in
Old 03-13-2006, 10:33 PM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
also with a married setup it can get pricey real fast when trying to match spline counts and bolt patterns. plus 2wd tranny's are SO much easier to find!
-cutts-
Old 03-13-2006, 10:38 PM
Skipped_link's Avatar
Skipped_link
Skipped_link is offline
Originally Posted by chrono4
what are the pros and cons to running a divorced vs a married? .
If you don't get married you won't have to get devorced, You knew that was coming,
Easier to clock a devorvce mount unit, no bolt patterns just a new fabbed up mount,
Old 03-13-2006, 10:47 PM
RawPower's Avatar
RawPower
RawPower is offline
not to steal your thread... but does anyone know if I can in some way put a divorced unit on my tranny? I mean, I know its possible, but can I just get the end part fro a 2wd ZF and bolt that on and then put the NP205 on? or should I just get married? If I put a married on the ZF, can I twinstick it?
Old 03-13-2006, 10:56 PM
KubotaOrange76
Originally Posted by RawPower
should I just get married? can I twinstick it?
dont get married
and theres no need in makin them more complicated than they already are
Old 03-14-2006, 12:05 AM
mustange70's Avatar
mustange70
mustange70 is offline
The spline counts for the frod trucks ain't as bad of a worry since fromt he mid 70's up though the 90's they were the same.
Old 03-14-2006, 12:09 AM
RawPower's Avatar
RawPower
RawPower is offline
What will I have to change on my shifter? should I search? sry, i dont think ive seen this one on here before, and i did search Pirate...
Old 03-14-2006, 12:13 AM
mustange70's Avatar
mustange70
I think that you can do it the same way you would do it on a nv -435 tranny,as the mounts are quite similar between the zf and a 435, and in the late 80's they were both used with the bw 1356 tc, and the shifter mount on the 435 didn't change, so i doubt it'll be to hard.
Old 03-14-2006, 12:15 AM
RawPower's Avatar
RawPower
RawPower is offline
ok, thanks... But I thinkI am going to get married bc I found one for $150 locally, and ive been searching for a while. they are like gold down here...
Old 03-14-2006, 12:19 AM
mustange70's Avatar
mustange70
yeah, don't forget to build a side mount for that pig of a 205tc, heres what i did (you can use your stock crossmember too that one is out of an 87 3/4t, theres plenty of clearence, or should be anyway, thats a 435/205 setup):
https://www.ford-trucks.com/user_gal...=52301&width=0
Old 03-14-2006, 12:31 AM
RawPower's Avatar
RawPower
RawPower is offline
yeah i dont want to crack my tailhousing on theZF...
Old 03-14-2006, 12:54 AM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
Divorced, allows more freedom but will cost you half of everything, married less freedom but only slowly bleeds your resources, oohh wait your talking Tcases well now thats differnt
Old 03-14-2006, 07:13 AM
cleatus12r's Avatar
cleatus12r
cleatus12r is online now
Butt-Head
Received 1,970 Likes on 1,105 Posts
You found one for $150!?!?! Mail order bride I suppose. She'll probably be more willing to cook and clean. Better than gold I say.
Cody
Old 03-14-2006, 09:54 AM
KubotaOrange76
is that per week or month??
if its a one time fee then i want in on this deal
Quick Reply: divorced vs married
