Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > New Jersey Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
New Jersey Chapter Join Chapter Leader: sddesigns
  #1 (permalink)
Old 03-13-2006, 08:25 PM
fordxfour87 fordxfour87 is offline
Garage is empty, add now
fordxfour87 is starting off with a positive reputation.
Muffler
In nj dose the state reqiure you hav muffler on your car/truck. Also can the exuasht come out the side of the vehicle?
  #2 (permalink)
Old 03-13-2006, 09:01 PM
Jmudder79's Avatar
Jmudder79 Jmudder79 is offline
Jmudder79 has a good reputation on FTE.Jmudder79 has a good reputation on FTE.
You need mufflers and depending on the year of your truck you may need cats. Check out the thread right after this one about emissions. It has a little more info for ya. Exhaust out the side is fine.
__________________
You may be a redneck if . . . you have spent more on your pickup truck than on your education.
  #3 (permalink)
Old 03-13-2006, 09:07 PM
ok, exhuast before the rear wheel is that ok?
Thats what i ment, cuase from factory, it comes out the side from the rear.
My bronco II has cats, and there staying in. They dont bother me. I need a new muffler, and was wondering if i could go by without one. Anyway, do you know if an after market muffler (such as magnaflow, etc) would be a problem?
Thanks
  #4 (permalink)
Old 03-13-2006, 09:22 PM
Jmudder79's Avatar
You would need a muffler. My exaust exits right in front of the rear tire and I never get any trouble about it. Aftermarket mufflers will be fine as long as they are not those "race only" type mufflers. I have Flowmasters on my truck and I went through inspection fine.
__________________
  #5 (permalink)
Old 03-13-2006, 09:45 PM
great!!, i sure hope they dont bother me about doing that with a bronco II. Im getting a sport muffler, prolly the same as stock lol. Maybe a little louder. Heck it looks cool as hell, and it beats getting a whole new tail pipe.
  #6 (permalink)
Old 03-14-2006, 02:07 AM
neversosure's Avatar
neversosure neversosure is offline
neversosure is starting off with a positive reputation.
The muflers have to exit the "passenger" compartment area.... meaning if you have a bronco the have to exit via the rear of the vehicle. If you have a pick-up the mufflers can end under the bed area past the cab which is the "passenger" compartment. I ended mine one foot after my cab under the bed and put turn downs on ends of the flowmasters pointing out to the sides of the truck.
__________________
1982 f150 stepside
351c 4v CC, 4500 stall, 4.56, 12.1, 825 BG Race demon,john deere blitz black 12.50 @ 109.3 mph
1989 F250 4X4
351w, 5spd, 3.55, 33" BFG, 1996 front end
  #7 (permalink)
Old 03-14-2006, 10:31 AM
Someone told me it must be past the last opening window....so i may be able to do it, sence it only has the two front windows, and the rear ones are sealed.
Its stupid if it still must be past that,even though the rear window cant be opened, and the pipe is past the front opening window on the door
  #8 (permalink)
Old 03-18-2006, 03:20 PM
gunslingr76 gunslingr76 is offline
gunslingr76 is starting off with a positive reputation.
In New Jersey, the law specifically states that a vehicle shall be equipped with a muffler in good working order and in constant operation to prevent excessive or unusual noise and annoying smoke, and no person shall use a muffler cut-off, bypass or similar device upon a motor vehicle on a highway. No where have I found that the location of the tail pipe is relative to anything. Just keep in mind that if a M.V. Inspector can show that emissions are getting into the cab compartment of the vehicle, then the vehicle can be considered " unsafe" and be towed from the highway.
  #9 (permalink)
Old 03-19-2006, 04:03 PM
well, anyway, i gots a new thing im doing.
I ordered a LMC truck mag, and they have a pretty cool dual exuasht im getting for my birthday. Instead of mufflers, it has "resinator" tips on the end of each pipe. I guessing thats what quites it up, but leaves a mild deep tone. Its also 50 state legal, so i should pass inspection with no problems.Both pipes run out the rear of the vehicle so even if there is a law about side exhuast, it wont apply to me.
I understand that it should be on there for noise control, but dose it really control smoke to any extent? I never knew that if it dose, i always though that all smoke, and emmsions control was done via the catalitic converter, maybe you said that by mistake, current i have no muffler on my truck (sits in the yard for now, until i get a permit/license, im fixing it up) and there obsolutely no smoke other then some steam that comes out of the ehxuast
  #10 (permalink)
Old 03-20-2006, 08:40 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
A muffler will not control smoke.
__________________
Ken
X Ranger, BII & NJ Chapter Moderator
2000 XLT Sport SC 3.0
2002 XLT Std Cab Long Bed 3.0
1989 Custom Std Cab Short Bed 2.9
  #11 (permalink)
Old 03-20-2006, 09:09 PM
73f100shortbed 73f100shortbed is offline
73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold
Mufflers do not control smoke. IN NJ you do need to have a muffler. It can be loud since NJ DMV does not use anything to measure noise for inspection, but they do run mirrors under the cars/trucks to make sure it has cats/mufflers. Your tailpipe should come out past rear tire on a BII as far as I know. "Must exit after last opening window". Even though side windows do not open they could give you some grief about it depending on who does the inspection. NJ is not so fun for inspection. I hate living in NJ for inspection reasons ha.
  #12 (permalink)
Old 03-20-2006, 09:21 PM
yeh well, i do suppose it better then california.....i heard there VERY strict, but however, im keeping both cats in my truck and im running the 50 state legal dual exhuast i talked about before.
Tags
muffler, nj
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
