Rear differential temperature sensor? - Ford Truck Enthusiasts Forums
Old 03-13-2006, 04:55 PM
rcknrbn rcknrbn is offline
rcknrbn is starting off with a positive reputation.
I've ordered a transmission temperature gauge as well as a pod that mounts on the pillar. However, the pod has an opening for two gauges. I'm going with the "Autometer" brand, "Z" series.
I've looked at a 2nd gauge to fill the other spot and am considering a differential temperature gauge.
http://www.autometer.com/cat_gaugelist.aspx?sid=12&opid=2&szid=2
I know some people that have added an oil pressure gauge in the 2nd spot, water temperature, tach. etc, but it seems that would just be duplicating the OEM gauges I already have.
Anyone added a differential temperature gauge? Seems like there would not be a port to install the sensor other than the drain / access plug. I'm only considering such a gauge as I do tow a travel trailer.
Any input is appreciated!
Old 03-13-2006, 06:47 PM
superrangerman2002's Avatar
superrangerman2002 superrangerman2002 is offline
superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.
Most just tap a hole in the diff cover in a area that won't interfere with the "guts" and just use a regular oil temperature sender just like the one you got for the tranny.
In all honesty you really don't even it it.
How ever a oil pressure gauge would be more legit. Most of the guages on your dash are nothing more than a glorified idiot light, this is especially true of the oil pressure gauge.
Once the motor registers something like 7 psi, the oil pressure "switch" closes and the guage snaps to the middle position.
Old 03-14-2006, 01:27 AM
PD52 PD52 is offline
PD52 is starting off with a positive reputation.
I recently installed a Mag-Hytec rear diff cover that has a sender port built in. I have been considering installing a diff temp guage also, but still not sure if its worth it. If you do some towing you might want to consider an aftermarket diff cover. The Mag-Hytec holds about 1 additional quart of fluid and has cooling fins as part of the cover. Just a thought.
Old 03-14-2006, 11:09 PM
Rear diff
The Mag-Hytec cover sounds like the way to go. I didn't realize they came with a sender port built in.
PD52 - where did you buy / order yours from?
The Ford OEM rear cover is junk. The paint all flaked off in the first couple of months.
Old 03-14-2006, 11:38 PM
Hello rcknrbn, I got mine from mag-hytec online. Here is the link: http://www.maghytec.com/index.asp?PageAction=VIEWCATS&Category=4
Also, I uploaded a couple photos of it in my gallery if you want to see mine. In the photo of the inside of the cover, you can see the little sender hole at the top, on the inside. I only have had it on for about 2 weeks and so far so good! It's a great looking mod. Anyways, hope this helps and let me know if you have additional questions.
Gauge Pod Locations? reptar0077 1999 to 2016 Super Duty 0 02-11-2017 12:54 AM
autometer gauge pod+isspro factory match gauges Blapensee 6.7L Power Stroke Diesel 19 12-18-2015 10:05 PM
2011 Super Duty Autometer 3 Gauge Pod Long Haul 6.2L V8 2 05-03-2015 01:36 PM
Pillar or dash pods for gauges? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 7 03-27-2015 11:55 PM
Gauge Pod Question bass-n-fire 1994.5 - 1997 7.3L Power Stroke Diesel 21 03-07-2015 12:44 PM
Tags
differential, gauge, rear, temp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
