Iowa Chapter Join Chapter, Leader:
What do you think?
Old 03-20-2006, 04:44 PM
Flareside94's Avatar
Flareside94
Flareside94 is offline
4WD have usually a 2" block in the rear, 2WD only have a 1" that I've seen, sometimes a 2" if they have a really soft spring back there. Also the coils used up front are slightly taller, and also slightly stiffer.
Old 03-21-2006, 07:19 AM
69 and 85's Avatar
69 and 85
69 and 85 is offline
I looked at a bunch of frontends in the junkyard and since the I-beams are different, but simular (if that makes sense!) it is hard to see the difference. Stiffer springs is really hard to see , but it makes sense when coupled with the slightly taller spring and I-beams.
I didn't look at the rears since I don't think I have a problem there, but good info that that I'm sure will come in handy someday!
Thanks guys.
