1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Intermittent 4 wheel drive
Old 03-12-2006, 12:36 PM
superpony18's Avatar
superpony18
superpony18 is offline
I woke up to 6 inches of snow this morning and went to the store. Well on my way up a hill in 4H, auto hubs in the manual position, My rear tires started to spin. I put it back in 2 then back in 4H and it started working. I never shut off the truck and in the 7 miles I drove I had to reingage it 5 times. I just had new bearing assemblies put in and new o-rings. Thank you for your help.
Old 03-14-2006, 11:55 AM
1975Ford's Avatar
1975Ford
1975Ford is offline
I perfer the part-time hubs over the auto hubs. Go with the better Warn hub or multi mile hubs. The auto hubs if not greased properly will not engage. And can easily get damaged if the truck is engage in 4x4 and the hubs did not engage and suddenly engage.
-Buck-
Old 03-14-2006, 01:33 PM
biz4two's Avatar
biz4two
biz4two is offline
With the auto hubs in the manual "LOCK" position...I am thinking this is a transfer case issue. Because going from 2hi to 4hi will not re-engage the front hubs...since they are already in the manual "LOCK" position.
Looking at the internals of the hubs, I do not think it is possible for them to go back from the manual "LOCK" position...into the "Auto" position. Of course...it could be that the hubs are stripped. But they usually still work if you put the hubs in "LOCK".
I recommend having the hubs in "LOCK" and check the axle knuckle area if the axle rotates. If it does...then the hub is malfunctioning. If not...then it is ok.
biz
Old 03-14-2006, 11:22 PM
superpony18
Thank you for the info. I have not gotten a chance to check it out further do to snow and no garage. Will inform as soon as possible.
Old 03-15-2006, 11:39 AM
1975Ford's Avatar
1975Ford
1975Ford is offline
On the auto hubs, need to use proper grease on the hubs or they will have a hard time engaging.
Here is some additional info https://www.ford-trucks.com/forums/s...25&postcount=6
Old 03-16-2006, 09:14 AM
superpony18
Ok, yesterday I raised my truck off the ground everything seems fine, except when I turn on the 4x4 iget vaccum to my hubs for about 30 seconds then I lose vaccum, and my hubs disengage. thanks for the link. T-case shifts fine.
Old 03-16-2006, 10:27 AM
1975Ford's Avatar
1975Ford
1975Ford is offline
What year and model are you working on?
Old 03-16-2006, 10:35 AM
Big Orn's Avatar
Big Orn
Big Orn is offline
From this descprition, you had the hubs locked, right? You manually moved the hubs from AUTO to LOCK...correct?
I can't see what switching the dial would have done unless you didn't get them fully locked to begin with.
At any rate, the hubs seem to be bad.
Old 03-16-2006, 10:58 AM
superpony18
It is an 01 PSD with an auto. Yes when I was driving with the hubs in the lock position it would disengage but still show 4x4. When I raised it off all fours I forgot to try manually locking them. My drivers side hup won't engage rught away, as sson as I start to move it crunches and pops rear bad then works fine. I think the four wheel drive is disengaging when I lat off the throttle. (an after thought)
Old 03-16-2006, 11:26 AM
Big Orn's Avatar
Big Orn
Big Orn is offline
With the open diff, you won't get one wheel pulling up front. If one hub fails, the other axle is useless...no load.
Also the hubs are energized via the vacuum solenoid and is independent of the transfer case. When you said, "four wheel drive is disengaging" you meant that you were losing power to the hubs I suppose. Or did you actually see (get under the truck)if the front drive shaft had disengaged with the 4WD lights still on?
Old 03-16-2006, 11:46 AM
superpony18
I was heading up a snow covered paved road had to let off the throttle for another car when I got back on it rear tires spun 4wd light still on hubs manually locked. Turned the switch from 4h to 2h and back just fine.
Old 03-16-2006, 12:21 PM
1975Ford's Avatar
1975Ford
1975Ford is offline
You had me confused when you mentioned Auto hubs on your original post.
Manual hubs, Maybe to much grease on hubs, either way the hub will need to be inspected and cleaned or maybe replaced.
-buck-
Old 03-16-2006, 12:37 PM
superpony18
they are the auto/manual hubs
Old 03-16-2006, 12:45 PM
FortyFords's Avatar
FortyFords
FortyFords is offline
Once you lock a a auto /manual hub to the manual lock position, unless the hub is bad internally it will stay locked in, no matter what you do with the 4x selector sw.
Now remeber that a 4x4 is really only a 3w drive truck 1 front 2 back (if you have a ls unit )
Now all bets are off if you have aftermarket lockers installed.
Only thing that may have happened is transfercase shift motor got a eroneous signal from the relays and 4x control module somehow.bad wiring loose gnd somewhere corrosion in the connectors or water intrusion in connectors.
Rich
Old 03-16-2006, 01:01 PM
1975Ford's Avatar
1975Ford
1975Ford is offline
part-time hubs
Quick Reply: Intermittent 4 wheel drive
