4.6 with aluminum block - Ford Truck Enthusiasts Forums
Old 03-11-2006, 11:35 PM
ejriede ejriede is offline
ejriede is starting off with a positive reputation.
Hey, I just bought a 2003 Exp with the 4.6 aluminum block engine. I did not realize it had an aluminum block until after I purchased the truck. I have been reading the treads and have not read much about these engines and there expected life. Are they as reliable as the old cast block 4.6? I had a 96 F-150 with one and it had 173k and was running strong.
Old 03-12-2006, 11:58 AM
TGJ TGJ is offline
TGJ is starting off with a positive reputation.
I am not sure how they stand up in trucks, but in the cars, they live a long and happy life just like the cast ones. Many car performance guys prefer the aluminum block to the cast one because it is lighter and the aluminum block is the only one that you can do a Big-Bore to. If you don't really want it, you can replace it with a cast one and sell your aluminum one to a mustang guy.
Old 03-12-2006, 01:35 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.
Is this the 4V head 4.6? I was looking online and Ford Racing offers those as crate motors for $5500. Other parts are bit more expensive to replace, as well... probably due to it's limited production, yet hi-po nature.
-Kerry
Old 03-12-2006, 03:56 PM
TGJ TGJ is offline
The Explorer got a 2V Aluminum motor and I believe the 06 Explorer has an Aluminum 3V motor. The main difference between the Explorer and normal 4.6 was the blocks and accessory placement. This motor will have the same heads, cams, pistons, rods, crank as the mustang motor. I haven't checked out FRPP on their 06 catalog, but they did not offer this as a crate motor in 05. The only crate 4.6L motors I have seen was the 99 Cobra, 00 Cobra and 03-04 Mach1 motors.
If you are referring to the 5.0L DOHC Big-Bore Cammer motor. The last time I checked the 5.0L Cammer was $15000.00 and just the block was $3100.00. You don't need the 4V heads for a 5.0L Big-Bore, I have a Big-Bore 2V motor to go into my TBird.
Old 03-12-2006, 09:53 PM
I like it very much it runs great. I plan on keeping it a long time it has 40k on it now. And I read somewhere that it was only good for 100k. This statement worried me and I was trying to get some answers. If it were not as good as the old cast I might try to get out of . hoping to hear some 200k 300k stories on the aluminm block. I believe it has 2 valve heads.
Old 03-12-2006, 09:56 PM
TGJ TGJ is offline
It has 2V heads. Treat it well and you will see 200 - 300 K on it pretty easily.
Old 03-13-2006, 12:19 AM
When he wrote Exp, I was thinking Expy... hence the 4V Navi motor question. I, as well as others, refer to Explorers as Exploders ....knock on wood .
-Kerry
Old 03-13-2006, 01:30 AM
yardbird's Avatar
yardbird yardbird is offline
yardbird is starting off with a positive reputation.
The 2003 Expeditions 4.6s have the all aluminum engine in them. I have one. The question I have is are the cylinders sleeved? I would hate to think Ford left the cylinders aluminum like Chevy did with the early Vegas.
If the cylinders are not sleeved I may be having mine for sale soon.
2003 is the only year that the 4.6/2V was used in the Expedition.
Old 03-13-2006, 07:56 AM
TGJ TGJ is offline
The Aluminum motors are sleeved.
Old 03-13-2006, 12:39 PM
yardbird's Avatar
Quote:
TGJ: The Aluminum motors are sleeved.
Thank goodness. I didn't think Ford would be stupid enough to not sleeve them, but in these days of cost cutting at the expense of quality, you never know.
Old 03-13-2006, 11:08 PM
Unfortunately the sleeves don't just slide out, though. The aluminum is cast around them.
-Kerry
Old 03-14-2006, 03:16 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Quote:
the 4.6 2v was used in all expy's as the base engine from 1997-2004
Old 03-14-2006, 03:25 PM
yardbird's Avatar
ford390gashog posted:
I was referring to the all aluminum 4.6/2V as only being available in the Expedition for model year 2003. I guess I forgot to put all aluminum in that sentence.
I did read like I was stateing that the 4.6 was only in the 2003, but that is not what I meant, just the all aluminum 4.6 in 2003.
Thanks for pointing out my omission, it could have led someone wrong.
Do the 4.6L engines have roller rocker failures? fordiesel69 2004 - 2008 F150 4 12-15-2016 01:05 PM
2004 Expedition 4.6 Crown Victoria engine swap please help ! 2004EXPEDITION4.6L Expedition & Navigator 4 07-21-2015 08:27 PM
04 Expedition 4.6L alloy block engine? DJPRacer58 Expedition & Navigator 0 11-18-2011 09:15 AM
4.6l aluminum blocks. What were they in 59flatbedford Modular V8 (4.6L, 5.4L) 27 03-02-2010 10:00 PM
5.4 vs 4.6 - which to purchase? exdodgeguy 1997 - 2003 F150 12 07-04-2005 08:58 PM
Tags
46, aluminum, block, ford, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
