Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Iowa Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
  #1 (permalink)
Old 03-11-2006, 06:55 PM
Sam_Fear's Avatar
Sam_Fear Sam_Fear is offline
Garage is empty, add now
Sam_Fear has a good reputation on FTE.Sam_Fear has a good reputation on FTE.
Electrolysis rust removal
I read about this in another forum one day and finally decided to try it. Don't know if anyone in this forum has tried this, but it works great! I was really impressed. Tried it on a few old rusty tools I had thrown in a box. Doesn't bring it back to new, but it sure is easy.
Besides that, I spent most of the day organizing my garage/shop.
What a great day!
__________________
I'm nothing more than words on your monitor.
  #2 (permalink)
Old 03-12-2006, 07:06 PM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
Never really tried such, but then, haven't been exposed to it too much either. Care to link to it?
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 03-13-2006, 06:03 AM
Dave Severson Dave Severson is offline
Dave Severson is gaining momentum as a positive member of FTE.
You should also be aware that any electolysis, including chroming, will also weaken the part.......
__________________
Anybody can restore a classic, takes a man to cut one up......
  #4 (permalink)
Old 03-14-2006, 05:48 PM
Sam_Fear's Avatar
Quote:
I assume you mean Hydrogen Embrittlement. I've read that it disapates with time and the process can be speeded by cooking the part at 300 degrees for awhile. I don't plan to use the process on anything critical though.
Also know that Stainless Steel should not be used as a conductor as some sites suggest.
__________________
  #5 (permalink)
Old 03-14-2006, 06:00 PM
Sam_Fear's Avatar
Quote:
Well, I read about it alot, and thought about it a long time before I decided to try it. Something about water and electricity that makes me wary.
Anyhow, here are a couple of the better sites I found on the subject:
http://antique-engines.com/electrol.asp
http://myweb.tiscali.co.uk/andyspatch/rust.htm
http://users.andara.com/~pspencer/ns...is.html#safety
As a warning, my battery charger finally quit working after using it for this for a couple days - it was very fritzy anyhow, and is why I used it. I really don't think the electrolysis fried it, it was just its time. I plan to try it again.
Edit: I also was hooking the charger directly to the electrodes without using a battery as a buffer. Probably makes a difference too.
__________________
Tags
77, cab, davenport, electrolesis, electrolysis, f150, forum, ia, removal, rust, shops, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
