Freeze Plug Location - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 03-11-2006, 04:33 AM
tomucen tomucen is offline
tomucen is starting off with a positive reputation.
I want to replace my old freeze plugs with brass ones as recommended in this forum. I am about to ask a friend in the US to buy them and send them over.
I looked into the manual yesterday and tried to find a picture that shows me how many freeze plugs the engine has and where they are located. Unfortunately I did not even find a hint. Can someone help me? And what's the best way to get the old ones out?
Old 03-11-2006, 05:35 AM
krankshaft's Avatar
krankshaft krankshaft is offline
krankshaft is starting off with a positive reputation.
They are located towards the bottom of the block.
A screw driver works to remove them a socket and a hammer is a good tool to reinstall them.
It is a little cramped around them so be sure to take your time and have your tools ready.
Old 03-11-2006, 05:37 AM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
There are 3 plugs in the engine block (2 - pass. side, 1 - drv. side). 2 plugs in each head. It is easier to replace plugs in the block from underneath (remove the oil filter before). I use a big screwdriver and hammer to get old ones out.
Remove plugs from head from under the hood (remove PS pump and alternator before) and from the insede the cabin (there is a hatch), but remove a coil before.
I used RTV with new plugs to prevent leackages.
It is easy to make new plugs. You need to find a shop with lathe. Cheap job here. I made them of stailess steel.
Old 03-11-2006, 05:40 AM
I have fogotten about 2 plugs under the flightwheel! To replace them you have to remove a tranny!
Old 03-11-2006, 11:06 AM
JTHill24 JTHill24 is offline
JTHill24 is starting off with a positive reputation.
tomucen:
Go here http://jthill.herringtontech.net/aerostar/engine.html
and you can see where they are.
The Block uses 5 of them that are 1 1/2"
The Heads use 4 of them that are 1 1/4"
JaY
Old 03-12-2006, 12:24 AM
krankshaft's Avatar
You'll also notice in one of those pictures is the block coolant drain screw directly under the drain plug which I was able to break loose during my coolant flush in addition to draining the radiator prior. I wanted to drain as much coolant as possible.
Since your replacing the plugs you may want to try to remove it and put some anti-sieze on it.
Old 03-12-2006, 07:06 PM
cbr900 cbr900 is offline
cbr900 is starting off with a positive reputation.
be warned this is a really akward job to do it is really difficault to get at the freeze plugs with the engine in place. Taking then out is not the hardest part putting them back in is, you can't get a good straight hit on them with a hammer which you need to do to be able to put then back in correctly. I found a small bottle jack and some 2x2 wood helpfull to get them back in, you have to place the wood on the frame rail then the jack with a socket the right size to fit inside the freeze plug, once you have got them started with the jack you can then tap them in the rest of the way with a small hammer.
Old 03-13-2006, 09:15 AM
I dont know why, but for me it is easier to put it them in! I use hammer and a little bar to do it!
Old 03-14-2006, 06:21 AM
oh boy, I don't think I'll do that. Looks like a nightmare.....
Old 03-14-2006, 06:53 AM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
unless you are having a freeze plug leak problem, I would leave them alone...with full flush and antifreeze change every 2 years and using only distilled water, the freeze plugs will last as long as engine rotating components...
if you rebuild engine, change freeze plugs then, coat inside and out with this or similar product prior to install and let dry...will outlast driver
http://www.permatex.com/products/automotive/automotive_gasketing/gasket_sealants/auto_Permatex_High_Tack_Gasket_Sealant.htm
i use this every fall...many similar anti corrosion water pump seal lubricant products
http://www.acdelco.com/html/pi_vehcare_lub.htm
Old 03-14-2006, 07:36 AM
It is really posiible, but forget a hope to be clean after that! Use glowes! I did it twice!
Old 03-15-2006, 06:32 AM
thanks for info. The engine is dry so I'll leave them alone. I am due for a coolant flush anyway next month. And the spark plugs are due in summer so I will get my share of bruised knuckles anyway.....
Old 03-15-2006, 06:35 AM
Sometimes freeze plugs and hoses may leak ufter cooling system flush.
Old 03-15-2006, 01:51 PM
copper_90680's Avatar
copper_90680 copper_90680 is offline
copper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant futurecopper_90680 has a brilliant future
Quote:
Tomucen:
What size of engine do you have? 3.0L or 4.0L?
Old 03-16-2006, 06:14 AM
I have the 3.0
New To Me 92 F150 - Freeze Plug? StephenM 1987 - 1996 F150 & Larger F-Series Trucks 4 02-25-2017 08:31 PM
replacing freeze plug Old Brown Truck FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 10-06-2015 10:51 PM
1994 5.8l freeze plugs Bigjim94 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 09-05-2013 12:58 PM
throttle body freeze plugs leaking szealuss 1987 - 1996 F150 & Larger F-Series Trucks 0 10-17-2010 10:40 AM
Freeze plug location??? Jetsfan68 Modular V10 (6.8l) 4 01-01-2006 03:19 PM
Tags
30, 305, 40, 96, aerostar, block, core, f150, ford, freeze, location, plug, removal, v6, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
