engine id's
Old 03-11-2006, 12:04 AM
Jon Henry's Avatar
Jon Henry
Jon Henry is offline
Question engine id's
Is there some source to check out that shows what an original engine and it's hookup look like?? I've got a '36-85HP in my '38 1/2 ton. It's a definite rebuild bec. of the good shape it's in, has 21 studs, and is stamped 68==== on the heads. The hoses come in at the top-front of the heads and the water pumps are just below them. I've seen pic's of other '36-7-8's with hoses and pumps in various different positions. I know it doesn't matter much except for ordering eng. parts and maybe wiring. I'm mainly curious. Tks~JH~
Old 03-11-2006, 01:05 AM
restoringmy46's Avatar
restoringmy46
restoringmy46 is offline
Go to www.vanpeltsales.com When you get there click on (The Flathead Homepage) there is alot of info on there that will help you out with your motor. Scott
Old 03-11-2006, 10:11 AM
mtflat's Avatar
mtflat
mtflat is offline
A picture of the engine would be interesting - sounds like a 37/8 block with 36 heads. I'm curious what they did for water pipes on the front of the head where the old pumps bolted on.
Old 03-11-2006, 04:09 PM
Jon Henry's Avatar
Jon Henry
Talking eng. pics
Hey Tim;
There are some pics of my '38 in the gallery, not the best for the front of the motor but you can kinda see the left pump and the hoses. Didn't know the heads could be switched. Like I said, just curious mostly.
Later~Dan~
Old 03-11-2006, 06:56 PM
mtflat's Avatar
mtflat
mtflat is offline
Ok Dan, I just read your first post more carefully..... thought you meant the wp's were mounted on the front of the block below the hose connections. From the picture and what you said it does appear to be a 36 engine - at least by the head designation. About the only parts question you might get is whether it has babbit for bearings or insert bearings.
All 21 stud heads will physically interchange, but you have plumbing issues if you mix them up. I have a 36 engine that is fairly complete and a 37 block that is all busted up from freeze cracks, but it came with the wp block-off plates indicating it had been used with 36 or earlier heads.
Nice truck btw! If you have any other questions, I promise to read/reply slower.
Old 03-12-2006, 12:49 AM
Jon Henry's Avatar
Jon Henry
Thumbs up eng.id
Thanks for the advice. Went to vanpelts and checked out their info. Looks like my motor is actually from a '36 car, cool! The more I find out, the more I don't know. Later~JH~
06FUN
10-29-2016 07:53 AM
TowsonX
1999 to 2016 Super Duty
01-11-2014 10:25 PM
mikerons
03-04-2007 11:36 AM
Jon Henry
1947 and Older Ford Trucks
08-02-2005 08:26 PM
Quick Reply: engine id's
