Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-11-2006, 12:04 AM
Jon Henry's Avatar
Jon Henry Jon Henry is offline
Garage is empty, add now
Jon Henry is starting off with a positive reputation.
Question engine id's
Is there some source to check out that shows what an original engine and it's hookup look like?? I've got a '36-85HP in my '38 1/2 ton. It's a definite rebuild bec. of the good shape it's in, has 21 studs, and is stamped 68==== on the heads. The hoses come in at the top-front of the heads and the water pumps are just below them. I've seen pic's of other '36-7-8's with hoses and pumps in various different positions. I know it doesn't matter much except for ordering eng. parts and maybe wiring. I'm mainly curious. Tks~JH~
  #2 (permalink)
Old 03-11-2006, 01:05 AM
restoringmy46's Avatar
restoringmy46 restoringmy46 is offline
restoringmy46 is starting off with a positive reputation.
Go to www.vanpeltsales.com When you get there click on (The Flathead Homepage) there is alot of info on there that will help you out with your motor. Scott
  #3 (permalink)
Old 03-11-2006, 10:11 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
A picture of the engine would be interesting - sounds like a 37/8 block with 36 heads. I'm curious what they did for water pipes on the front of the head where the old pumps bolted on.
  #4 (permalink)
Old 03-11-2006, 04:09 PM
Jon Henry's Avatar
Talking eng. pics
Quote:
Hey Tim;
There are some pics of my '38 in the gallery, not the best for the front of the motor but you can kinda see the left pump and the hoses. Didn't know the heads could be switched. Like I said, just curious mostly.
Later~Dan~
  #5 (permalink)
Old 03-11-2006, 06:56 PM
Ok Dan, I just read your first post more carefully..... thought you meant the wp's were mounted on the front of the block below the hose connections. From the picture and what you said it does appear to be a 36 engine - at least by the head designation. About the only parts question you might get is whether it has babbit for bearings or insert bearings.
All 21 stud heads will physically interchange, but you have plumbing issues if you mix them up. I have a 36 engine that is fairly complete and a 37 block that is all busted up from freeze cracks, but it came with the wp block-off plates indicating it had been used with 36 or earlier heads.
Nice truck btw! If you have any other questions, I promise to read/reply slower.
  #6 (permalink)
Old 03-12-2006, 12:49 AM
Jon Henry's Avatar
Thumbs up eng.id
Quote:
Thanks for the advice. Went to vanpelts and checked out their info. Looks like my motor is actually from a '36 car, cool! The more I find out, the more I don't know. Later~JH~
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
