99 f150 wheel size
I believe the original question was in regards to the rim size. Like said above, the studs size I beleive changed after 2000 so you should be fine, just make sure you have the right lug nuts.
As far as tire size, that depends on 2wd or 4wd and there is a very lengthy sticky about that. I fit 285x75 r16 tires on 16x8 wheels with stock lift on my 99 4x4. They are 32.9" tall, which is taller than some 33" tires. And it appears I have more room than with the 265's that were on it on stock wheels.
CPerry
06-03-2003 08:09 PM
lt dan
05-25-2001 12:43 PM
