99 f150 wheel size - Ford Truck Enthusiasts Forums
99 f150 wheel size
Old 03-10-2006, 07:31 PM
chickenman76 chickenman76 is offline
chickenman76 is starting off with a positive reputation.
99 f150 wheel size
Hey everybody I'm fixin to buy a 99 f150 lariat excab 4x4 It has 17" rims on it now my question is will a 16" rim fit I have a set of 16's off of my 98 150 that i rolled last year and would really like to use them any help is much appreciated
Old 03-10-2006, 07:41 PM
MrBSS MrBSS is offline
MrBSS is starting off with a positive reputation.
I believe they will fit. I have a 2001 which came with the (optional) 17" wheels, and I have used 16" snow tires and wheels. I think the '99s are similar in that regard.
There was a change in stud size around 2000, which shouldn't affect your situation.
Old 03-11-2006, 06:44 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome chickenman to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 03-11-2006, 12:47 PM
Smaug's Avatar
Smaug Smaug is offline
Smaug is starting off with a positive reputation.
stud size is irrelevant, just use the lug nuts that came on the truck
Old 03-11-2006, 06:52 PM
looneylariat looneylariat is offline
looneylariat is starting off with a positive reputation.
My '99 F-150 came with 16's. My tire size is 255/70/16. As long as your tires aren't much taller I don't think you'd have a problem.
Old 03-12-2006, 12:01 AM
78bigbronco's Avatar
78bigbronco 78bigbronco is offline
78bigbronco is gaining momentum as a positive member of FTE.
I believe the original question was in regards to the rim size. Like said above, the studs size I beleive changed after 2000 so you should be fine, just make sure you have the right lug nuts.
As far as tire size, that depends on 2wd or 4wd and there is a very lengthy sticky about that. I fit 285x75 r16 tires on 16x8 wheels with stock lift on my 99 4x4. They are 32.9" tall, which is taller than some 33" tires. And it appears I have more room than with the 265's that were on it on stock wheels.
2003 and 2004 17" rims RustyTrustyF150 Brakes, Steering, Suspension, Tires, & Wheels 0 11-10-2014 07:57 PM
Rim size 2003 f150 2003 5.4l General Automotive Discussion 1 06-11-2014 01:40 AM
Rim help SC78f150 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-15-2014 08:56 PM
16" rims on f150? big-ugly 1987 - 1996 F150 & Larger F-Series Trucks 76 03-06-2011 08:36 PM
33/11.5 tires on 16x7 rims? CPerry Brakes, Steering, Suspension, Tires, & Wheels 4 06-03-2003 09:09 PM
Tags
16, 1999, 2557016, 4x4, 99, alternate, combo, f150, f150s, rim, size, sizing, tire, tirewheel, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
