Useless windshield defroster - Ford Truck Enthusiasts Forums
Old 03-10-2006, 01:25 PM
fgiord fgiord is offline
fgiord is starting off with a positive reputation.
Does anyone else but me think that th 150 FX4 supercrew defroster is just about as useless as all *&%$, it takes forever to thaw out even a little ice or snow and you can forget about the windshield washer when there's ice...I had a F350 that used to blow you away when plowing, you had to keep the window open, this thing i need to block off the passenger side vent with my gloves just to keep the drivers side clear.
Old 03-10-2006, 01:44 PM
WhlM1's Avatar
WhlM1 WhlM1 is offline
WhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant future
Welcome to FTE. I dont have any complaints about the defroster in my supercrew. Maybe there is something wrong with yours?
Old 03-10-2006, 01:54 PM
ReForder ReForder is offline
ReForder is starting off with a positive reputation.
I don't rely on the defroster to clear ice off my windshield, I use a scraper for that. But what I have noticed is difficulty keeping the windshield clear on really damp days, regardless of outside temp. I can barely keep a small viewing area open on the windshield and the front drivers and passenger windows, but forget the rear door or rear window glass. I don't think the defroster vents are aimed properly, or they don't have the proper dispersal pattern for the greenhouse on these vehicles.
Old 03-10-2006, 02:11 PM
I scrape the snow and ice off also, my problem is when it snow hard it builds up too much. It sounds like it blowing up a storm on high but it won't keep it clear. I even crack the widow thinking that it might help relieve internal pressure to no avail
Old 03-10-2006, 06:07 PM
jdwheels jdwheels is offline
jdwheels is starting off with a positive reputation.
No probs here. Maybe you have a door sticking in mix box??
Old 03-11-2006, 02:48 PM
emdgealc emdgealc is offline
emdgealc is starting off with a positive reputation.
we have the opposite problem here in lower alabama
last night while out with the 06 supercab, the outside air temperature was 74 yes 74, and 90 percent humidity, the stupid windshield was fogging up on the outside i.e moisture condensing in the windshield
looks like the air duct doors are screwed up, great, now they have to pull the dash
Old 03-11-2006, 06:13 PM
bigdavewilson bigdavewilson is offline
bigdavewilson is starting off with a positive reputation.
Quote:
I've had a problem with a stuck thermostat on both my 02 and 04 5.4 engines. This had a considerable effect on the air temperature from the heater defroster.
Might be worth getting checked out.
With the thermostat working right the windshield defrost function works great.
Old 03-11-2006, 06:37 PM
tula771 tula771 is offline
tula771 is starting off with a positive reputation.
Got a 2006 XL 150, was a little annoyed with the defroster, I live in Michigan. But, I have a Freestar with the 3.8 and its a little slow to warm, so the 4.2 also is a little slow. I've learned to defrost the winshield first, then change the mode to the dash vents to get the sides and back, works quite well.......but the engine is slow to warm.
Old 03-11-2006, 08:46 PM
alxsnmr alxsnmr is offline
alxsnmr is gaining momentum as a positive member of FTE.
May want to check to make sure that the outside vent for the system isnt plugged. I had a 91 t-bird that did what you were discribing and it was the intake for the system was covered with some air silencing materail from the factory that fell down. Otherwise you may have to go through the system to make sure all the doors and vents are opening right.
Old 03-11-2006, 09:54 PM
the_webers_inc the_webers_inc is offline
A mostly quiet Supporter
the_webers_inc is gaining momentum as a positive member of FTE.the_webers_inc is gaining momentum as a positive member of FTE.
A note on Defoging your windows on a damp, humid day/morning:
As silly as it may sound, hit the A/C button. Even though you are on hot defrost, this will help because one of the functions of A/C is to dry the air. So you get hot dry air hitting your windshield instead of damp hot air.
It's Just my theory, but has worked great for me.
T. J.
Old 03-11-2006, 10:10 PM
brymac brymac is offline
brymac is starting off with a positive reputation.
Almost all domestic vehicles turn the ac compressor on when you turn the selector switch to defrost.
Old 03-12-2006, 05:54 AM
Almost All. My 95 F150 did, but I notice that my new 06 F150 Does not.
T. J.
Old 03-12-2006, 09:51 AM
silverfrost99 silverfrost99 is offline
silverfrost99 is starting off with a positive reputation.
Also make sure you dont have the inside air reciculation position selected, by allowing outside air to heat or cool the vehicle, it equalizes the air moisture and drastically reduces fogging on the inside. I am not sure all model have this selection or not.
Old 03-12-2006, 12:19 PM
is300wrx's Avatar
is300wrx is300wrx is offline
is300wrx is starting off with a positive reputation.
juts put the setting on frull windshield, and level 4 on the level, and put it to hot when the truck is warm. Afterall, it is a V8 and no matter if you have a 4.6 or a 5.4, it will take some time for the engine to warm up
Old 03-23-2006, 03:57 PM
I'm just glad it's spring where I don't need to use the defroster again for a while (I hope)
No Defrost wingcat 6.7L Power Stroke Diesel 9 10-15-2014 07:22 PM
Ice on Inside of windshield Fordrangernewbie Ranger & B-Series 1 11-21-2013 09:09 PM
Blower motor issues Jeepincj7 1994.5 - 1997 7.3L Power Stroke Diesel 3 12-16-2012 11:25 AM
Block Warmer And Defrost spitball 1999 - 2003 7.3L Power Stroke Diesel 16 01-06-2004 01:36 PM
air conditioner/defroster 96 f150 seanboy Cooling, Heating, Ventilation & A/C 5 01-17-2003 11:55 AM
Tags
07, 2006, 98, alternate, defrost, defroster, doesnt, expedetion, f150, ford, problems, slow, turn, windshield, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
